Hi everyone, there's one video I seem not able to play in VLC or any other player. Here is the MediaInfo log:
Video
Format : AVC
Format_Profile : Main@L3.1
Format_Settings : CABAC / 4 Ref Frames
Format_Settings_CABAC/String : Yes
Format_Settings_RefFrames/String : 4 frames
CodecID : 7
Duration/String : 1 min 1 s
Width/String : 640 pixels
Height/String : 360 pixels
DisplayAspectRatio/String : 16:9
FrameRate_Mode/String : Variable
FrameRate/String : 29.970 (30000/1001) FPS
Standard : NTSC
ColorSpace : YUV
ChromaSubsampling/String : 4:2:0
BitDepth/String : 8 bits
ScanType/String : Progressive
colour_range : Limited
colour_primaries : BT.601 NTSC
transfer_characteristics : BT.601
matrix_coefficients : BT.601
Audio
Format : AAC
Format_Profile : LC
CodecID : 10-2
Channel(s)/String : 2 channels
ChannelPositions : Front: L R
SamplingRate/String : 48.0 kHz
FrameRate/String : 46.875 FPS (1024 SPF)
Compression_Mode/String : Lossy
Can you give an advice?
Thanks a lot in advance.
i not very good at this sort of problem but have you tried https://filehippo.com/download_klite_mega_codec/ plays everything i throw at it
RUN VIDEO THROUGH "Media Player Classic it come with the codec pack"
ALSO try re-encode the video through something like VIDCODER/HANDBRAKE see if that works??Last edited by BzERK IE; 18th Nov 2017 at 11:08.
What is the container format? What extension does the file have?
What will play avc file rendered by Vegas
By Anonymous in forum Newbie / General discussionsReplies: 6Last Post: 2nd Mar 2016, 21:07 -
Cannot play .avc in mpc-hc 64 bit
By rogeiro in forum Newbie / General discussionsReplies: 2Last Post: 5th May 2015, 01:50 -
How to verify a MPEG-TS/AVC video
By RixNox in forum Newbie / General discussionsReplies: 7Last Post: 19th Nov 2013, 03:31 -
Convert Video to HD with AVC and MP42
By akhilrajau in forum Video ConversionReplies: 1Last Post: 24th Aug 2013, 21:28 -
converting or rendering video to AVC HD-Mpeg4
By Tom in HD in forum MacReplies: 2Last Post: 5th Jun 2013, 11:36
