OK, I'm a newbie at this so please be gentle...I want to convert an eac3 audio track to ac3. Popcorn is supposed to do this using the 'Re-sample AC3 Audio Tracks' menu item. When I add my input file to the small window you get when I click on this menu item it informs me that it 'Cannot read source file using MediaInfo.DLL'. I have MediaInfo.DLL pointed to appropriately. If I put the same input file into the main program it gets the media info correctly. As a matter of fact when I input the file name in the small window, and the complaint appears, it actually DOES read the info and outputs it in the main program window. What am I doing wrong?
https://www.videohelp.com/software/eac3to Command line tool but a GUI is available
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Thanks for the link. If I understand correctly (always a big 'if') the command line version requires demuxing first then remuxing afterword, and though I had a look at one of the GUIs it added even more complexity to the task.
I really don't want to learn more about the ins and outs of audio/video. Life's too short. I just have a problem with the fact that the MKV videos I download are now showing up with E-AC3 audio which my Sony TV won't accept. I just want a one-click solution to address this that does it relatively fast. I am now using HandBrake but it does not have a passthru for video mode so it takes too long to change the audio to plain AC3. If I could just get Popcorn to work I suspect I would be happy with it. -
I suggest you post on the Popcorn Forum as the author is often there. http://www.networkedmediatank.com/index.php
Take a look here http://www.networkedmediatank.com/showthread.php?tid=20887
Popcorn Audio Converter is Backdoor Trojan...
By snadge in forum Video ConversionReplies: 3Last Post: 24th Nov 2015, 09:52 -
Help with Popcorn Audio Converter
By DigiToss in forum Video ConversionReplies: 2Last Post: 11th Dec 2014, 12:48 -
Popcorn audio converter: Convert without remuxing?
By cinesimon in forum AudioReplies: 2Last Post: 23rd Apr 2014, 20:19 -
PopCorn MKV Audio Converter
By cata1569 in forum Blu-ray RippingReplies: 5Last Post: 5th Jan 2014, 14:29 -
Audio Converter (Popcorn) Problem
By netmask56 in forum AudioReplies: 2Last Post: 4th Nov 2013, 03:08
