hi guys, i need to ask about error in MeGUI. i'm trying to encode 720p x265 10bit. then i check the log got some error, it says "Standard error stream".
but i'm still able to finish all my encode. playing the video just fine. i just want to know about that error.
Not at all a new question...
Because the "standard output stream" = STDOUT is often redirected into pipes, command line applications often prefer the "standard error stream" = STDERR as an alternative path to display messages which should certainly appear on screen (eventhough it can be redirected as well).
Yet, the name does not mean that everything written there is always an error message. In your case, there is no (!) [error] message (abort, cannot continue). Only (i) [info] messages (read if you like - or ignore) and /!\ [warning] messages (please note, but it still works). No reason for panic.
tl;dr: There is no error.Last edited by LigH.de; 28th Oct 2017 at 15:19.
you (or megui) set level 3.1 in command line , look can here https://en.wikipedia.org/wiki/H.264/MPEG-4_AVC#LEVELS
standard says 14000 maximum, you had there about 30000,
so guessing, with smaller buffers you have less reference frames available, if you put it all in some equation,
In your case both are set, buffers and reference frames so I guess priority was level for x264
EDIT: I see it is x265, but same principle is perhaps applied -
MeGUI New Error Messsage
By yaston in forum Video ConversionReplies: 7Last Post: 15th Sep 2015, 07:40 -
MeGUI Value error
By Chriscoder in forum Newbie / General discussionsReplies: 2Last Post: 13th Jan 2015, 15:01 -
Megui error??
By vl4d in forum Newbie / General discussionsReplies: 8Last Post: 25th Dec 2014, 17:04 -
MeGUI error
By hector1980 in forum Blu-ray RippingReplies: 1Last Post: 5th Sep 2013, 17:02 -
What am I doing wrong? - Error in MeGUI
By socrates in forum Video ConversionReplies: 4Last Post: 6th Aug 2013, 15:12
