Hi,
There is a video from a kaltura link that I want to download via ffpmeg.
I've tried multiple variations of ffpmeg syntax to try and download it, with no success.
Here is one example
ffmpeg -i "https://cfvod.kaltura.com/hls/p/1067292/sp/106729200/serveFlavor/entryId/0_z3waapci/v/2/pv/4/flavorId/0_v7e2xtou/name/a.mp4/index.m3u8" -c copy index.mkv
One consistent error message I receive each time is " No trailing CRLF found in HTTP header."
I am able to download this video using a addon in firefox, but the download is so load that it always fails before the entire video is downloaded. I would like to use ffpmeg to download the entire video successfully.
Thanks in advance for any suggestions
Results 1 to 12 of 12
I have no idea why it does not work for me.
What I tried using the command, I received this message
PHP Code:[https @ 0653adc0] No trailing CRLF found in HTTP header.
Input #0, hls,applehttp, from 'https://cfvod.kaltura.com/hls/p/1067292/sp/106729200/serveFlavor/entryId/0_z3waapci/v/2/pv/4/flavorId/0_v7e2xtou/name/a.mp4/index.m3u8':
Duration: 00:44:08.09, start: 0.101000, bitrate: 0 kb/s
Program 0
Metadata:
variant_bitrate : 0
Stream #0:0: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 640x360 [SAR 1:1 DAR 16:9], 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc
Stream #0:1: Audio: aac (LC) ([15][0][0][0] / 0x000F), 44100 Hz, stereo, fltp, 98 kb/s
Stream #0:2: Data: timed_id3 (ID3 / 0x20334449)
File 'index.mkv' already exists. Overwrite ? [y/N] y
[matroska @ 068ac100] Codec for stream 0 does not use global headers but container format requires global headers
[matroska @ 068ac100] Codec for stream 1 does not use global headers but container format requires global headers
[matroska @ 068ac100] Error parsing AAC extradata, unable to determine samplerate.
Output #0, matroska, to 'index.mkv':
Metadata:
encoder : Lavf56.40.101
Stream #0:0: Video: h264 (H264 / 0x34363248), yuv420p, 640x360 [SAR 1:1 DAR 16:9], q=2-31, 29.97 fps, 29.97 tbr, 1k tbn, 90k tbc
Stream #0:1: Audio: aac ([255][0][0][0] / 0x00FF), 44100 Hz, stereo, 98 kb/s
Stream mapping:
Stream #0:0 -> #0:0 (copy)
Stream #0:1 -> #0:1 (copy)
Could not write header for output file #0 (incorrect codec parameters ?): Invalid argument
I just downloaded the most recent version of ffpmeg and I'm still getting the above error.
the ffmpeg output I get:
Code:ffmpeg version 3.3.2 Copyright (c) 2000-2017 the FFmpeg developers built with gcc 7.1.0 (GCC) configuration: --enable-gpl --enable-version3 --enable-cuda --enable-cuvid --enable-d3d11va -- enable-dxva2 --enable-libmfx --enable-nvenc --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libb s2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --ena ble-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enabl e-libopenh264 --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libsnappy --enable -libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-l ibvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-l ibx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enabl e-zlib libavutil 55. 58.100 / 55. 58.100 libavcodec 57. 89.100 / 57. 89.100 libavformat 57. 71.100 / 57. 71.100 libavdevice 57. 6.100 / 57. 6.100 libavfilter 6. 82.100 / 6. 82.100 libswscale 4. 6.100 / 4. 6.100 libswresample 2. 7.100 / 2. 7.100 libpostproc 54. 5.100 / 54. 5.100 [hls,applehttp @ 03197b20] Opening 'https://cfvod.kaltura.com/hls/p/1067292/sp/106729200/serveFl avor/entryId/0_z3waapci/v/2/pv/4/flavorId/0_v7e2xtou/name/a.mp4/seg-1-v1-a1.ts' for reading Input #0, hls,applehttp, from 'https://cfvod.kaltura.com/hls/p/1067292/sp/106729200/serveFlavor/ entryId/0_z3waapci/v/2/pv/4/flavorId/0_v7e2xtou/name/a.mp4/index.m3u8': Duration: 00:44:08.09, start: 0.101000, bitrate: 0 kb/s Program 0 Metadata: variant_bitrate : 0 Stream #0:0: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 640x360 [SAR 1:1 DAR 16:9 ], 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc Metadata: variant_bitrate : 0 Stream #0:1: Audio: aac (LC) ([15][0][0][0] / 0x000F), 44100 Hz, stereo, fltp Metadata: variant_bitrate : 0 Stream #0:2: Data: timed_id3 (ID3 / 0x20334449) Metadata: variant_bitrate : 0 Output #0, matroska, to 'index.mkv': Metadata: encoder : Lavf57.71.100 Stream #0:0: Video: h264 (Main) (H264 / 0x34363248), yuv420p, 640x360 [SAR 1:1 DAR 16:9], q= 2-31, 29.97 fps, 29.97 tbr, 1k tbn, 90k tbc Metadata: variant_bitrate : 0 Stream #0:1: Audio: aac (LC) ([255][0][0][0] / 0x00FF), 44100 Hz, stereo, fltp Metadata: variant_bitrate : 0 Stream mapping: Stream #0:0 -> #0:0 (copy) Stream #0:1 -> #0:1 (copy) Press [q] to stop, [?] for help [hls,applehttp @ 03197b20] Opening 'https://cfvod.kaltura.com/hls/p/1067292/sp/106729200/serveFl avor/entryId/0_z3waapci/v/2/pv/4/flavorId/0_v7e2xtou/name/a.mp4/seg-2-v1-a1.ts' for reading [hls,applehttp @ 03197b20] Opening 'https://cfvod.kaltura.com/hls/p/1067292/sp/106729200/serveFl avor/entryId/0_z3waapci/v/2/pv/4/flavorId/0_v7e2xtou/name/a.mp4/seg-3-v1-a1.ts' for reading etc. -
Thanks Jabago for testing this out. I'm not sure what I can do differently, but you have shown it is possible to download this video.
I am using Windows 10. I wonder if, Jagabo, you are using a different operating system and it could perhaps account for why you can download the video and it doesn't work on my computer. I'm just guessing about this.
I'm using Win7. But I just tried it on a Win10 computer and had no problems. Maybe it's the Great Firewall that's causing your problem.
Hi ,
Working for me ( under win XP ) , with :
Cheers .Code:livestreamer "hls://https://cfvod.kaltura.com/hls/p/1067292/sp/106729200/serveFlavor/entryId/0_z3waapci/v/2/pv/4/flavorId/0_v7e2xtou/name/a.mp4/index.m3u8" live -o Hitler.mp4
JE SUIS CHARLIE !!! -
I used your above ffmpeg code and downloaded with no problem.
I uploaded the file here (313MB):https://files.videohelp.com/u/61125/in.mkv
If you have problems downloading the file, try using a download manager like IDM. -
Help needed with downloading this video (m3u8)
By hopepper in forum Video Streaming DownloadingReplies: 4Last Post: 13th Oct 2016, 14:08 -
Downloading .M3U8 / .F4M
By JoshuaGV in forum Video Streaming DownloadingReplies: 2Last Post: 22nd Jun 2016, 00:56 -
Need help downloading video from ABC (m3u8) to mp4 (will pay $10)
By jiberishedspam in forum Video Streaming DownloadingReplies: 6Last Post: 9th Dec 2015, 14:37 -
help downloading ooyala m3u8 video
By krito in forum Video Streaming DownloadingReplies: 4Last Post: 16th Jun 2015, 22:04 -
Need some guidance with downloading m3u8
By ManiKz in forum Video Streaming DownloadingReplies: 0Last Post: 1st Apr 2015, 19:53
