I found the packaged 40463 Virtualdub. But when I choose x264-8 also ffmpeg x265, I get no sound in the mp4 output file.
I was wondering if I was missing something when saving. I did try .AVI output and there was sound.
New user of VD and love Deshaker on a train ride in Colorado.
Results 1 to 9 of 9
I've never used it. I guessed that you did from your question. But now (sorry for the misunderstanding) I see what you are talking about: Compression menu, "FFMPEG / x265"
I tried the following and it seemed to work fine:
[Attachment 43514 - Click to enlarge]
[Attachment 43515 - Click to enlarge] -
You have been a great help. I did the save as and chose "Any format by FFMPEG (*.*)" like you said.
And it worked. ( And VLC loved it ) Renamed the extension as it still showed as .AVI to .MP4. Ran Mediainfo on it
and it said .MP4 and showed the audio in it. Now I can say I believe in RiffRaff ( RaffRiff ). Ha ha
Thanks -
Further.. I cannot imagine the amount of math involved in deshaking.
And I worked for IBM in hardware and software... -
To get a better understanding of what is going on, run mediainfo on your original .mp4 and the .mp4 created by simply altering the .avi extension.
Look at the audio codec in particular.
Essentially, you got lucky since you do not really have a proper .mp4 container file but still an avi which has an audio codec that is supported under .mp4. In fact a proper .mp4 only supports a few audio codecs - mpeg (mp3) and AAC. Your avi could have had another audio codec and it still would not have audio had it been a proper .mp4.
The ffmeg demo as above works since it will only encode audio to a format that is supported for a proper .mp4 -
"Any format by FFMPEG" simply allows to detect container format by filename extension. This way it is possible to save formats not listed explicitly (I tried .webm with vp8 codec for example).
However, codec compatibility is not verified. If something is wrong (like uncompressed audio in mp4) the result is just "ffmpeg error" message.
Issues to save an output file, MKV, HEVC (H.265) on VirtualDub FilterMod
By ResetMaster in forum EditingReplies: 5Last Post: 30th Aug 2017, 11:40 -
Which exe to use to run VirtualDub FilterMod?
By kingmustard123 in forum Video ConversionReplies: 4Last Post: 23rd Jul 2017, 13:27 -
Which filters recommended for VirtualDub(Filtermod)?
By PabstBlueRibbon in forum EditingReplies: 3Last Post: 22nd Jul 2017, 11:00 -
VirtualDub FilterMod (build 40035/release) ISSUE!
By david.dgc in forum Video ConversionReplies: 7Last Post: 20th Jul 2017, 05:43 -
Is the VirtualDub FilterMod better than VirtualDub?
By ResetMaster in forum Video ConversionReplies: 26Last Post: 2nd Jul 2017, 14:08
