  1. so there is absolutely nothing out there to check movies for Cinavia protection. just asking for a checker. I did use CinDe but was told that Cinavia has now been updated to v4.0 in july 2017. so CinDe is no longer any good. will they be updating CinDe as well. unless there is another checker about.
    will CinEx HD Utility check movies for Cinavia as I see it says it will remove it. but how can you tell if its on the movie if you cant check 1st
    I am thinking of buying CinEx HD Utility as it says $39.99 approx 30GBP which isnt too expensive. But dont want to pay that if its no good
    Aug 2002
    South Florida
    CloneBD does.
  3. Originally Posted by pepegot1 View Post
    CloneBD does.
    but it wont check .avi, mp4, or mkv as it says no BDMV structure found
