I am using The free Cinavia Detector v0.95 from http://www.cinexhd2.com
I tested a movie which is .mp4 it said no cinavia detected. so i then convert movie to VOB files DVD, also again checked each VOB file for cinavia
same thing again no cinavia detected, burnt movie to DVD but when I tried to play in my blue ray player after 10 mins again it pops up with cinavia
so obvious this CineDe cinavia detector isn't working right.
would anyone know of a more better detector
Results 1 to 10 of 10
Yes but this is only a trial version so how can it remove it. whats full price in GBP
as how comes CinDe says non detected on a .mp4 movie also after i converted to DVd yet when it plays it says its there
This dvdfab dont even say where to remove cinavia its just a trialLast edited by natty; 24th Oct 2017 at 11:46.
the trial version is limited to 1 use copy. here's more information & a guide and pricing - https://www.dvdfab.cn/dvd-cinavia-removal.htm?trackID=productspage
The utility stopped detecting Cinavia protection some time around July with the introduction of Cinavia V4.0.
http://www.cinexhd2.com/cinavia-4-0/
Cinavia has changed somewhat since it was first used. The latest release of the CinDe is from June of 2016. The blog post I link to is from July of 2017. In short, Cinavia detectors may not be 100% reliable at this point. -
You better spend this money on better player like android tv box($35-$80) or PC
that can play any 4k video or audio file from usb flash drive or network:
https://www.youtube.com/playlist?list=PLPFDS-HuO3zlZ9KdG6bV1KY9KgQAnaOUQ
I have dedicated PC (Core i3,Windows 10+Kodi) to play any files
not have to deal with cinavia nonsense or other copy protection -
Yeah I do believe its mostly blueray players what picks that cinavia up. so I will try and get a cheap non blue ray player
Would this CinDe checker be updated soon then as thats the only program to check them
Is there a program what list movies which have cinavia protection on themLast edited by natty; 25th Oct 2017 at 05:32.
cinavia protection detector
By loa909 in forum Newbie / General discussionsReplies: 3Last Post: 17th Oct 2017, 05:44 -
HDS Link detector not working?
By maniac8828 in forum Video Streaming DownloadingReplies: 3Last Post: 31st Jul 2016, 22:01 -
Removing Cinavia protection,100% working method
By stijo Mathew in forum Video ConversionReplies: 31Last Post: 8th Mar 2016, 01:30 -
so confused. HDS Link detector
By angles in forum Video Streaming DownloadingReplies: 3Last Post: 12th Dec 2014, 05:47 -
Cinavia PS3 Fix Error, any working solutions?
By ceceliagibson in forum Newbie / General discussionsReplies: 11Last Post: 2nd May 2014, 01:13
