What does that "Codec-friendly sizing" option do? Let's say I want to upscale my video to 8x, will changing it to "Multiples of 8" do anything?
Depend on codec - for some it can be 16 for some 8 for some 64 or more (depend on max block size).
No, it adjusts the output size you ask for to be divisible by 2, 4, 8 etc.
8x enlargement is always going to be mod 8, but the problem can arise if you enlarge by percent.
For example 640x480, enlarged 1.33 = 851.2x638.4. Without adjustment, that's 851x638. Odd sizes are usually not allowed except in RGB mode. Adjusted to mod-8, that's 848x632 (try it).
Note this can warp the aspect ratio a tiny bit. -
Oh... that's a shame then. I thought it had anything to do with compressing the files better.
I'm trying really hard to find a good compression method here. I work with pixel oriented game videos and capture them with a lossless codec (either camstudio or lagarith) at RGB, then upscale them to either 8x or 9x with point resize. But they add up and take a lot of space here in my HDD.
Do you guys have any compression tips for archiving purposes?
WebEx WMV file, can't open in VirtualDub, says "missing codec"
By violetta in forum Newbie / General discussionsReplies: 13Last Post: 22nd Jul 2016, 21:39 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 07:21 -
[Help] Problems with the "Title Button" in the "VTS ROOT" and "VTS Normal"
By kirous in forum Authoring (DVD)Replies: 8Last Post: 1st Nov 2014, 12:31 -
"Internet Friendly Media Encoder" Is HEVC supported by any browsers?
By Stears555 in forum Video ConversionReplies: 13Last Post: 21st Sep 2014, 16:23 -
Why/when to use codec friendly sizing in the VDub resize filter?
By brassplyer in forum EditingReplies: 2Last Post: 25th Oct 2012, 10:07
