I currently have a receiver that can process AC3, but I plan on buying one that will have DTS.
I have an MKV that has DTS only. I want to add AC3 so I have audio now, but I want to maintain the DTS for the future receiver.
Can 5.1 DTS and 5.1 AC3 coexist in a single MKV such that all appears/sounds normal so as to take advantage of different audio receivers with different 5.1 surround sound capabilities?
I'm using MKVToolNix to join/mux the two files.
Any sound advice? Pun intended!
TIA!
From high up here above earth, it's obvious our perspective is limited. -
They can exist in a mkv,you just have to switch audios,they won't both play at the same time.
Make sure the AC3 is in sync with the video. Otherwise it’s pointless.
Hi,
actually one mkv file can contain very much Videotrack also. Not appended, independent on each other, audiotrack and subtitles as well. So you switch video stream and is it. I thought there were problems with video track was played with different audio track. Just tested it and it worked well now.
I tested 5 video tracks with 12 audiotrack and 5 subtitles, but the limit of track is far beyond this (I belive)
Bernix -
Thanks guys, that really helped me to understand that I have many more questions to ask!
But seriously, Thanks much!
Happy New Year!From high up here above earth, it's obvious our perspective is limited. -
MOST containers allow for multiple video & audio tracks - it just depends on the muxers being used to put them together, and on the response (compliant or not, smart or not) by the downstream players, editors. I have worked out ways to do this for the various containers while experimenting with stereo3d methods & options, so can verify.
Scott -
Yes, MKV will allow both the DTS 5.1 track and the AC3 5.1 track. I would suggest muxing them together with mkvtoolnixgui and then make sure you set the preferred track as default or forced.
Mkv convert dts sound into ac3
By fits79 in forum AudioReplies: 5Last Post: 5th Jan 2017, 22:41 -
Anyway to convert MKV DTS to AC3 5.1 surround sound?
By Patsfan37 in forum AudioReplies: 24Last Post: 7th Jul 2016, 07:17 -
MKV - DTS to AC3 nightmare
By aaron1104 in forum AudioReplies: 29Last Post: 1st Mar 2015, 12:46 -
Conversion Error DTS-HD Master 7.1 to AC3 (PopCorn MKV AudioConverter)
By piknockyou in forum AudioReplies: 9Last Post: 9th Jun 2014, 10:49 -
MKV/DTS files to MKV/AC3 & AAC
By ktklein72 in forum AudioReplies: 0Last Post: 15th Feb 2013, 12:43
