I have copied (cloned) all my home videos from numerous DVDs to the hard drive of my computer. The quality varies as some were initially made on VHS cassettes.
I now want to edit some of the videos. I also want to keep all the videos in whatever format on the hard drive to stream it to my LG Smart TV.
Space on my desktop isn't really a problem, but I really do not want to lose video quality. Should I convert to mpeg2 (as the VOBs are in mpeg2) or to mp4 to first edit and then render?
What settings should I use when I convert? Should I, for instance, leave it interlaced, what bitrate, etc. I have Premiere Pro. (Should I use PP for the conversion or is there another programme that I can consider to use when converting?)
Hi,
try avidemux. Open Vob file here. It will load all parts at once (of movie). Then under video copy, under audio copy and output format try ts muxer. This way you get one file without reencoding (no lost byte). I dont know if Premiere pro will read it without problem, with sound etc. If not try rename the file from ts to mpeg. But it is not good to reencode video when you have DVD quality video. Actually yes, but when you will be finish with editing that you mentioned.
EDIT I mean not lost byte for MPEG-2 videos (vobs etc)
Bernix -
It depends on your computer etc. If you want smaller files with good quality then MP4 (it is container) so video x264 or x265. Depending where you want to watch your videos. If only on PC, then x265 video + aac audio will be best, If on tv, check what format it support. Answer can be very long, when I dont know what is the medium you want to watch your final video.
EDIT: for x265 I suggest you to use CRF constant rate factor, for x264 CRF about 18. Check the result, if is not good, lower CRF to 18 x265 or 16 x264.
Bernix -
An alternative option:
1. Use MakeMKV to extract the main movie from the ISO.
2. Use ffmpeg to copy the the audio and video from mkv to an mpg file.
3. Use Premiere Pro to edit and export as mpg or mp4.Code:ffmpeg -i <input.mkv> -vcodec copy -acodec copy <output.mpg>
Can I convert videos from a DVD to a file format such as MP3/MP4 surround?
By R.STEED in forum Video ConversionReplies: 1Last Post: 29th Sep 2017, 11:12 -
Audio lost in Handbrake during conversion from .webm to .mp4 format
By Cruisecontrol in forum Video ConversionReplies: 13Last Post: 19th Sep 2016, 17:15 -
Need to convert and author home videos that are 2 hrs. long & .avi format
By Studly in forum Newbie / General discussionsReplies: 11Last Post: 9th Dec 2015, 07:31 -
Need help with MP4 Format Conversion
By chuckman4112 in forum Video ConversionReplies: 8Last Post: 9th Mar 2014, 12:44 -
Need help converting home videos to mp4
By MrPinche in forum Video ConversionReplies: 3Last Post: 23rd Jan 2014, 10:11
