Hi cats
I use lsmash source 64bit in avisynth (64bit)
do you know if is there a 64bit versione of the old vfrtocfr.dll plugin?
and it need to works only with FFMS2.dll or can works also with lasmash? thanks
https://github.com/jojje/VfrToCfr-the-other-one/releases
Should work with every input plugin as long as you can supply a timecode file.
Like ffms2, lsmash also has vfr->cfr built-in via "fpsnum" and "fpsden" parameters. (Though I had erratic results with l-smash vfr->cfr in the past.) -
Converting vfr clips to VfW AVI-containered cfr lips
By turk690 in forum Video ConversionReplies: 1Last Post: 5th Feb 2017, 08:35 -
Turning video from VFR to CFR without re-encoding?
By yetanotherlogin in forum EditingReplies: 3Last Post: 29th Aug 2016, 11:09 -
VFR to CFR
By SameSelf in forum Video ConversionReplies: 6Last Post: 7th Jun 2016, 20:46 -
RipBot264 and Handbrake producing VFR when CFR is selected
By duffbeer in forum Blu-ray RippingReplies: 9Last Post: 22nd Jan 2015, 09:50 -
Syncing VFR Video with Audio from CFR Video
By Chri5 in forum Newbie / General discussionsReplies: 11Last Post: 25th Jan 2014, 04:17
