    Oct 2017
    Brasil/Campo Grande-MS
    Hi guys
    how to solve this error?
    Thx
    Mar 2008
    Do you have the Java runtime installed? It is required by this app.
    Oct 2017
    Yeah, the installed version is higher
  4. Anonymous
    Guest
    Perhaps the application requires 32-bit Java and you installed the 64-bit edition?
  5. Member Cornucopia's Avatar
    Java can have multiple versions installed. If that app likes/needs a certain version, re-install it. Just don't let it remove other versions - it should ask you.
    Note: to maintain full functionality for all cohabitating versions, they probably should reside in different directories.
    Aug 2013
    Central Germany
    Some JAR application packages also provide an EXE launcher, but they often look only for versions following a specific numbering schema (like "jre1*"). Java 9 default installations do not match such patterns.
    In addition:
    Java 9 suddenly requires an explicit parameter listing modules to be loaded, which breaks compatibility in both ways, because Java up to v1.8.* does not ignore this yet unknown parameter.
    Usually sufficient example for Java 9 starting a JAR application package:
    C:\ProgramData\Oracle\Java\javapath\javaw.exe --add-modules ALL-SYSTEM -jar application.jar
    If you know which, you can also list only the most vital modules.
  7. Anonymous
    Guest
    Thanks for the up-to-date info, LigH. I conclude Java 1.8 is the new Java 1.6.
    In addition:
