I'm trying to play back tapes on my camcorder so that I get the video (including my youngest son's birth) into a more useful format, but the video skips a bit and then the camera shuts down.
The only answer I got from JVC was to mail it to their service centre, with zero indication how much it would cost. I've read some info that cleaning it might help, but I'm not entirely sure how to go about that or, if it requires a cleaning tape, what kind I would need.
The camera hasn't really be used for about 5 years, I discovered it cleaning a couple weeks ago, so it's hopefully just dusty since it worked fine that last time I used it.
I'd appreciate any suggestions. The camera is a JVC model GR-D770U
Results 1 to 10 of 10
MiniDV camcorders are cheap, you can get a working used one rather than try to fix yours for a lot of money.
True, but make sure you get at least the same make as the one the tapes were recorded on and preferably the same model. DV camcorders are notorious for different brands not playing each others' tapes properly.MiniDV camcorders are cheap, you can get a working used one rather than try to fix yours for a lot of money.
Probably not problem on panasonic and sony, but DVCPRO is using wider track pitch.
From wikipedia
BernixWhen recorded to tape, DVCPRO uses wider track pitch - 18 μm vs. 10 μm of baseline DV, which reduces the chance of dropout errors during recording. Two extra longitudinal tracks provide support for audio cue and for timecode control. Tape is transported 80% faster compared to baseline DV, resulting in shorter recording time. Long Play mode is not available. -
Most likely a mechanical problem. Can you see if both reels are turning?
You can clean everything except the drum with cotton buds and 99% isopropyl alcohol. The drum and video heads should be cleaned with chamois swabs and alcohol.The only answer I got from JVC was to mail it to their service centre, with zero indication how much it would cost. I've read some info that cleaning it might help, but I'm not entirely sure how to go about that or, if it requires a cleaning tape, what kind I would need.
Cleaning is not a bad idea, but your camera probably needs to be re-lubricated. Lubricants turn to sludge over time and stop up the works.The camera hasn't really be used for about 5 years, I discovered it cleaning a couple weeks ago, so it's hopefully just dusty since it worked fine that last time I used it. -
That's not a job you want to take on yourself unless you have the proper tools and the patience of a watchmaker.
Hi8 capture using Digital8 camcorder - Edge color issues
By memrah in forum Capturing and VCRReplies: 56Last Post: 4th Jan 2023, 10:36 -
Playback issues
By efiste2 in forum Newbie / General discussionsReplies: 7Last Post: 29th Jun 2015, 13:09 -
MPC-HC playback issues .. [resolved]
By vhelp in forum Software PlayingReplies: 12Last Post: 10th Aug 2013, 15:58 -
PLAyback Mode Issues
By akerekes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 8th May 2013, 23:23 -
VCR -> DV Camcorder -> PC Capture Issues
By Tony Jenkins in forum Capturing and VCRReplies: 6Last Post: 30th Dec 2012, 00:30
