I am a newbie and use VideoRedo TV Suite. My son recorded several videos on his Galaxy S5 for a school project and we attempted to merge them into a single file. VideoRedo merged the first two with ease. But when I tried to join the 3rd file, I got the following error:
"Unable to add the current video project to the joiner. It's [sic] frame rate is not compatible with the existing joiner entries of 29.95 fps."
I tried Googling the error, and it seems that the frame rates *must* match. VideoRedo will author DVDs, so some people have suggested "authoring" each of the segments separately (as VideoReDo TVSuite does not reencode except when authoring a DVD) and joining them afterwards.
Is there an easier way with other software? Preferably freeware since I already own VideoRedo and don't particularly want to buy another piece of software?
Thanks.
Hi,
you can try Mkvtoolnix. But result will be .mk I think it gives you warning but multiples o.k. If resolution is same and audio format too. You can then re-encoded final file to (i hate it) peak frame (that means variable framerate)
29.95 seems weird to me. Isnt it just 29.97 ?
If you try mkvtoolnix then open first file and click on it rmb and choose append. Append all file this way.
I just gave a try without success.
Bernix
Differing Frame Rates
By ron spencer in forum EditingReplies: 4Last Post: 8th Mar 2017, 22:59 -
Merge mp4 files without reencoding with Virtualdub ?
By ramaflore in forum Newbie / General discussionsReplies: 43Last Post: 24th Feb 2015, 03:19 -
Free program to merge mp4 & wmv video files with chapters?
By kcwebbah in forum Video ConversionReplies: 8Last Post: 28th Feb 2013, 16:07 -
Merge mp4 files(no convert)
By vsub in forum Video ConversionReplies: 4Last Post: 21st Feb 2013, 15:22 -
merge multiple mp4(h264) video the time frame get reduce by 10%
By redsunbird in forum Video ConversionReplies: 2Last Post: 15th Dec 2012, 03:32
