Hi all,
Sorry this is more of a capture and encode question. I'm capturing VHS in virtualdub and had some questions on the resync by insertion of null frames. My huffy avis after capture are synced beautifully. However, once I encode them in megui+avisynth, I'm getting sync errors that appear to be linked to the issue of insertion of null frames. I've included two clips where I had an insertion error. 1) is the in-sync avi direct from virtualdub and the 2) is my desired output, in mp4. The insertion error is about 5sec into the clip. Any suggestions on ways to handle this on either the capture side or the encoding side?
On the encoding side, use AVISource instead of FFVideoSource or LWLibavVideoSource and you will keep the duplicate frames, keeping everything in sync
Ah thank you for the quick reply. As I have a ton of these, I've been trying to do a fairly automated method in megui. Looks like it was using LWLibavVideoSource. Hmm trying to prioritize AVIsource now, I'm getting 'couldn't locate a decompressor for fourcc HFYU". I'll have to look into that a bit.
Is there a way to scan for null or inserted frames in Virtualdub?
By premiumcapture in forum RestorationReplies: 8Last Post: 28th May 2017, 23:32 -
How can I find corrupted frames in my encode?
By Ninelpienel in forum Newbie / General discussionsReplies: 23Last Post: 13th Dec 2016, 09:01 -
Basic NRE for Windows that can re-encode at given start/end frames?
By yetanotherlogin in forum EditingReplies: 4Last Post: 26th Feb 2015, 04:44 -
set FFMPEG so it encode all but without the first 10 frames
By marcorocchini in forum Newbie / General discussionsReplies: 33Last Post: 26th Oct 2013, 21:08 -
VFR Source.After encode,some frames remove,duplicated,remaining. Need help!
By xicudiz in forum Video ConversionReplies: 16Last Post: 9th Sep 2013, 01:06
