They both can pretty much trim, merge and put a video in a different container without losing quality. I tried looking at the alternative to section of the page of both XMedia Recode & AviDemux but they aren't in either of their list even though they are the same program.
They both have the ability to choose Mode > Copy on the Video and Audio tabs which is basically lossless.
Any similar software?
	They're not the same. Avidemux is a video editor and XMedia Recode is a video converter. "The greatest trick the Devil ever pulled was convincing the world he didn't exist."
	In good old days Virtualdub has this ability too. Copy video, copy audio. It has/d smart rendering function, but dont know nowadays situation.
 You can do same in Mkvtoolnix for example and it is also different category software.How aren't they the same? They're both FFmpeg GUIs that can do the same exact thing.
 Bernix
 I personally love AviDemux myself(I use an old, old version), but the odds of your cut falling exactly on a key frame(where it needs to be to be able to do it losslessly) are not good. So if you are just starting to delve into this stuff....KEY FRAME.....a very important "term" or word for you to keep in mind.
  XMedia Recode - mkv settings for LG 3DTV (2011)? VidCoder works, XMedia notBy slit in forum Video ConversionReplies: 11Last Post: 23rd Aug 2017, 22:04
  Xmedia Recode - Ripping & Encoding about 50% onlyBy Paparazzi in forum Video ConversionReplies: 3Last Post: 3rd Nov 2016, 02:18
  Xmedia Recode & Variable Frame RateBy BazzaG in forum Video ConversionReplies: 8Last Post: 15th Aug 2015, 10:52
  XMedia RecodeBy Arthur_Ballsack in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2014, 05:30
  xmedia recodeBy MaxOne72 in forum Video ConversionReplies: 3Last Post: 7th Dec 2012, 13:09
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
