Hi. I have a 1280x720 wmv which I have to script with avspmod/DirectShowSource. (It's one of those wmv's that MeGUI doesn't like.) The vid is in 16:9 but should really be 4:3.
Had I been able to use MeGUI to index/script it, changing the AR would be easy, like this:
global MeGUI_darx = 4
global MeGUI_dary = 3
but that command doesn't work when I open the avspmod script in MeGUI.
Is there a command I can use? Googling it has failed me. Many thanks.
	Thanks, pandy. A tool called WMVARChanger set to 3:4 has corrected the vid.
  aspect ratio changeBy iggyk23 in forum DVD RippingReplies: 17Last Post: 20th Jul 2017, 15:14
  avisynth and pixel aspect ratioBy silicontrip in forum Newbie / General discussionsReplies: 6Last Post: 29th Sep 2016, 03:10
  Keep aspect ratio in AviSynth?By Downgraded286 in forum Video ConversionReplies: 61Last Post: 23rd Jul 2016, 17:15
  How to change aspect ratio MPEG2s?By HitTheRoad in forum MacReplies: 22Last Post: 5th Jul 2014, 04:57
  Change aspect ratio before or after encodeBy mrcoolekin in forum Newbie / General discussionsReplies: 10Last Post: 22nd Dec 2012, 16:47
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
