Hello!
I"m using Subtitle Edit v3.5.4
pressing F9 creates a new subtitle line in video position, great, but it also pauses the video/audio.
all i need is to use a hotkey to add lines without the video being paused.
is that possible ? If not then please recommend me another software that could.
thanks alot for this amazing forum.
Hi,
try - option - settings - shortcuts - inserts new subtitle to video and assign letter you want... Hope it will work.
sorry you should look at create under shortcuts and there is it.
BernixLast edited by Bernix; 18th Oct 2017 at 14:57. Reason: edit path option-settings-shortcuts-create-inserts new subtitle to video pos
You are welcome, I am happy to see that sometimes trying to help really helps
Bernix
Subtitle edit
By Costantinil in forum SubtitleReplies: 20Last Post: 28th Jul 2023, 08:41 -
problem with Subtitle Edit 3.4.11
By whitelighter27 in forum SubtitleReplies: 26Last Post: 1st Dec 2016, 13:55 -
subtitle edit
By mrgiannis in forum SubtitleReplies: 2Last Post: 11th Feb 2016, 10:50 -
Subtitle Edit 3.4.6
By Top Cat in forum SubtitleReplies: 1Last Post: 15th Apr 2015, 11:44 -
Subtitle Edit 3.4.6
By Top Cat in forum Newbie / General discussionsReplies: 1Last Post: 15th Apr 2015, 07:21
