  1. I just purchased the new HP DVD200i. I want to burn DVD video using DVD+R with menu and everything, but the authoring software that comes with the drive (Sonic MyDVD) does not satisfy me. Does anybody have a suggestion what application I can use to burn a DVD+R disc??? So far, I've only tried Ulead DVD Workshop, and it only works with DVD+RW, but not +R. I saw some post from other webboard, saying that Nero does not yet support +R, is that true? Thanks in advance for your reply. I appreciate it.
  2. You could try Ulead DVD MovieFactory. A free trial version is available.
    For more info: http://www.ulead.com/dmf/features.htm
    I used the product, but not with DVD (VCD only) and its easy to use.
    Good luck.
