Hello, and thanks in advance for any help. Also, if I posted this in the wrong place then please move it as necessary (and thanks).
For years I've happily used MeGUI to shrivel my DVDs and Blu-rays to .mkv files with 10-bit x264 video and Nero .m4a audio. Also, I've used Avidemux regularly to cut clips from these encodes without issue. Very recently I started using Pazera Free Audio Extractor to downmix the audios, as I find it much simpler for batch processing. Unfortunately, this new form of audio causes Avidemux to crash, but only if I try to play the .mkv; that is, I can load the .mkv in Avidemux, I can navigate forward-backward in the video, and I can save a section of the .mkv without issue, but if I try to actually play the file Avidemux crashes with the error message "ExceptionFilter. The application has encountered a fatal problem. The current editing has been saved and will be reloaded at next start." Clicking on "Show Details..." results in:
which to me is a foreign language. Please, does anybody know what this means and if there's a way to rectify it? I tried to register on the Avidemux forum but wasn't allowed to. Thanks again for any helpEXCEPTION_ACCESS_VIOLATION
RtlIsDosDeviceName_U [ntdll.dll]
ADM_setCrashHook [libADM_core6.dll]
UnhandledExceptionFilter [kernel32.dll]
EtwEventSetInformation [ntdll.dll]
_C_specific_handler [ntdll.dll]
RtlDecodePointer [ntdll.dll]
RtlUnwindEx [ntdll.dll]
KiUserExceptionDispatcher [ntdll.dll]
free [msvcrt.dll]
win32AudioDevice::localStop() [libADM_av_win32.dll]
audioDeviceThreaded:top() [libADM_coreAudioDevice6.dll]
GUIPlayback::initializeAudio() [avidemux.exe]
GUIPlayback::initialize() [avidemux.exe]
GUI_PlayAvi() [avidemux.exe]
HandleAction(Action) [avidemux.exe]
MainWindow::qt_static_metacall(QObject*, QMetaObject::Call, int, void**) [avidemux.exe]
QMetaObject::activate(QObject*, int, int, void**) [Qt5Core.dll]
MainWindow::actionSignal(Action) [avidemux.exe]
MainWindow::buttonPressed() [avidemux.exe]
QAbstractButton::toggled(bool) [Qt5Widgets.dll]
QAbstractButton::keyPressEvent(QKeyEvent*) [Qt5Widgets.dll]
QAbstractButton::mouseReleaseEvent(QMouseEvent*) [Qt5Widgets.dll]
QToolButton::mouseReleaseEvent(QMouseEvent*) [Qt5Widgets.dll]
QWidget::event(QEvent*) [Qt5Widgets.dll]
QToolButton::event(QEvent*) [Qt5Widgets.dll]
QApplicationPrivate::notify_helper(QObject*, QEvent*) [Qt5Widgets.dll]
QApplication::notify(QObject*, QEvent*) [Qt5Widgets.dll]
QCoreApplication::notifyInternal2(QObject*, QEvent*) [Qt5Core.dll]
QApplicationPrivate:endMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) [Qt5Widgets.dll]
QDesktopWidget::qt_metacall(QMetaObject::Call, int, void**) [Qt5Widgets.dll]
QGuiApplicationPrivate:rocessMouseEvent(QWindowSystemInterfacePrivate::Mo useEvent*) [Qt5Gui.dll]
QGuiApplicationPrivate:rocessWindowSystemEvent(QWindowSystemInterfacePriv ate::WindowSystemEvent*) [Qt5Gui.dll]
QWindowSystemInterface:endWindowSystemEvents(QFlags<QEventLoop::ProcessEv entsFlag>) [Qt5Gui.dll]
QEventDispatcherWin32Private:endTimerEvent(int) [Qt5Core.dll]
TranslateMessageEx [USER32.dll]
TranslateMessage [USER32.dll]
QEventDispatcherWin32:rocessEvents(QFlags<QEventLoop::ProcessEventsFlag> ) [Qt5Core.dll]
qt_plugin_instance [qwindows.dll]
QEventLoop::exec(QFlags<QEventLoop::ProcessEventsF lag>) [Qt5Core.dll]
QCoreApplication::exec() [Qt5Core.dll]
UI_RunApp() [avidemux.exe]
startAvidemux(int, char**) [avidemux.exe]
SDL_main [avidemux.exe]
ms2timedisplay(unsigned int) [avidemux.exe]
unknown function [avidemux.exe]
BaseThreadInitThunk [kernel32.dll]
RtlUserThreadStart [ntdll.dll].
Edit: Apologies for the emoticons in the above quote, not sure how to fix that.
EditEdit: In case someone finds it helpful I found a workaround, if not an actual solution, with help from someone at Doom9. Here's a link.
Results 1 to 1 of 1
Webm/MKV file crashes on Machete edit-save and makes mess in Avidemux
By gumbygum in forum EditingReplies: 6Last Post: 19th Mar 2017, 15:44 -
Avidemux crashes with many, many MP4 files. How to handle?
By Diana (Cda) in forum Video ConversionReplies: 6Last Post: 5th Feb 2017, 20:55 -
avidemux crashes
By naszdom in forum Video ConversionReplies: 4Last Post: 8th Mar 2016, 07:04 -
Video Mastering works crashes on MKV with A_AAC audio
By geneariani in forum EditingReplies: 4Last Post: 19th Jan 2013, 20:03 -
Bluray rip on MKV, Avidemux recompress with x264 -> Audio out of sync
By sierramike in forum Video ConversionReplies: 2Last Post: 13th Dec 2012, 04:47
