Results 1 to 14 of 14
    Sep 2017
    Japan
    Hi there
    Please refer to the following image URL.
    https://gyazo.com/29f6342baa546411f782de836173b464
    I would like to insert new frame such as I create text and image by myself.
    Looking for the button I can insert it, I cannot find.
    Please help me out so that I can insert.
  2. Is it this program ?
    https://github.com/NickeManarin/ScreenToGif/wiki/help
    Did you try this
    Insert: Options to insert animations inside the current one. It opens the Insert Frames window.
    Media Ctrl + Shift + O: Opens a file picker and gives you the option to insert images or videos into your current animation.
    You can also copy/paste slides (ctrl+c / ctrl+v)
    Clipboard: Copy, Cut and Paste. There's also a small button under the "Cut" button that shows your current clipboard, called "Show Clipboard".
    Copy Ctrl + C: Copies all selected frames into the clipboard. It opens the Clipboard panel as soon as you copy. Also, it selects the latest copied frames as the active clipboard entry.
    Cut Ctrl + X: Same as above, except that it removes the selected frames from the frame list.
    Paste Ctrl + V: Gets the current active clipboard entry and inserts the frames before or after the selected frame on the list. You can configure the paste behavior on the Clipboard panel.
    Show Clipboard: Opens the Clipboard panel.
    Sep 2017
    Japan
    @poisondeathray
    Thank you for your reply.
    My question is about creating a new frame and insert ing into my desired into the place.
    Please refer to the following URL
    https://gyazo.com/79e257c5e692a5a6f601bbc2d6f5147a
    I would like to insert a text or free-drawing which I created newly into my desired place such as the top and between 4 and 5.
    I will appreciate it if you answer me back.
    Sep 2017
    Japan
    @poisondeathray
  5. I don't use this program. But it looks like you just use the insert media command
    You should then be able to adjust the image order by cut / pasting (ctrl+x , ctrl+v)
    Sep 2017
    Japan
    @poisondeathray
    According to your reply, I am afraid we cannot do the below transaction.
    >You should then be able to adjust the image order by cut/pasting (ctrl+x , ctrl+v)
    I can understand how to insert an existing frame, though, would like to know new frame.
  7. Originally Posted by omaruko View Post
    Create a new frame in any image editor. e.g. gimp, ms paint, photoshop, irfanview, paint.net etc.... Make it the same dimensions as the frames your project
    Push the media button to import it into the existing animation. It will give you a pop up box to determine if you want to insert before or after current frame. You can "move" the location of any frame by cut/paste
    Sep 2017
    Japan
    @poisondeathray
    I narrowly have understood what you mean.
    Moreover, let me ask you further questions.
    1.File extension
    Existing frames are a gif file. Must I convert gif file from any file such as jpeg and png?
    2.Adjustment of size and position
    Please refer to the following URL.
    https://gyazo.com/236d04413c8580401b3dfbf07f09bc75
    How to adjust size and position in case I insert the new frame into an existing frame.
    Looking forward to having a reply from you.
  9. Originally Posted by omaruko View Post
    1.File extension
    I downloaded this program and tried it out. jpeg worked but png did not even though png was supposed to be supported
    The program might be able to adjust the size (I don't know if it can), but I find it easier in other programs, like an image editor , or whatever program you used to make the insert
    Sep 2017
    Japan
    @poisondeathray
    1.File extension
    Confirmed by your reply.
    https://gyazo.com/701fc227d9581055c0af63715c869437
    ①The current frame is No.4. How can I insert new frame
    into before No0 of the current frame.
    ②Image editor, what you mean is that I take another program?
    If so, must I adjust the size in another program?
    If not so, where is image editor in the current program?
    ③How I adjust image position?
  11. Originally Posted by omaruko View Post
    In the timeline view, before you insert the image, select frame zero (left click). Whatever frame is seleected before you insert, is the frame that it gives you the option of inserting before or after. In your example you had frame 4 selected before inserting.
    In addition, can move frames afterwards by cut / paste
    Yes, I find it easier in other program. I'm not sure if this program can do it, I didn't look at it too closely
    I'm not sure what you mean? If you've resized the image in another program, you can also adjust the framing of the image
    A gif can only have 1 set of dimensions (you cannot have variable frame sizes)
    Are you trying to create a gif for the final format goal? What is your final goal ? There might be easier to use / better programs for what you are trying to do
    Sep 2017
    Japan
    @poisondeathray
    https://gyazo.com/124f2b9b63865f2ce02c6433cc43cd60
    Once a frame is inserted into the existing frame, the size is automatically adjusted?
    If so, no need print editor?
    How I move frame No4 to No0?
    Regarding for the image position, I leave as it is. I am not sure how to transact it.
  13. Originally Posted by omaruko View Post
    Select No4 (left click) , Ctrl+X to cut , move cursor and select No0 (left click), Ctrl+V to paste
    Sep 2017
    Japan
    @poisondeathray
    Thanks to you for your patient and kind support, I successfully got it.
    Please assume this issue has been solved.
