i have some video at 2048x1152 that i need to resize to 1920x1080. i'd like to fold the resizing into other parameters i'm feeding x264 so i can do it all at once. i thought i'd use lanczos as the method but would be happy to be corrected if that's not the best method for this. what is the cli command for this? should i use fittobox? what is the syntax to do this resize?
thanks,
BabaG
	There is no "best" method for every scenario. They all have pros/cons. Your options areCode:--vf resize:1920,1080,method=lanczos
 You don't need fittobox because you're starting with 16:9 and ending with 16:9- method: use resizer method ["bicubic"]
 - fastbilinear, bilinear, bicubic, experimental, point,
 - area, bicublin, gauss, sinc, lanczos, spline
	thanks very much, pdr. very quick response. i'll try it soon. so, for lanczos, there's just the one option? no lanczos3, lanczos4?
 thanks again,
 BabaG
	Those are the only options because the patch was "borrowed" from ffmpeg swscale
 https://ffmpeg.org/ffmpeg-scaler.html
 If you're wondering, "spline" is sharper than avisynth's spline16, but softer than spline36
 But 2048x1152 => 1920x1080 isn't a large change, so you won't notice as much difference between them than if you were use a proportionately larger change
  x264 vs 265 question (4/3/2016)By nixiejames in forum Video ConversionReplies: 6Last Post: 4th Apr 2016, 15:54
  Question about resizing several videos at onceBy Basher06 in forum Newbie / General discussionsReplies: 22Last Post: 26th Mar 2015, 05:56
  ffmpeg + x264 noise reduction questionBy wallywalters in forum Video ConversionReplies: 2Last Post: 14th Oct 2014, 13:06
  X264 encoding questionBy imhh1 in forum Newbie / General discussionsReplies: 2Last Post: 18th Aug 2014, 20:21
  dumb question about x264 losslessBy deadrats in forum Video ConversionReplies: 4Last Post: 1st Jan 2013, 22:00
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
