Hi,
I used to capture DV video tapes from Panasonic NV-DV2000 player to my PC through firewire card. Recently my PC doesnt recognized anymore DV2000 (both two firewire output ports) and Im unable to capture tapes anymore to PC.
(but my PC still read from Canon camera firewire output port)
Any idea why is that and how i can make it work again?
Im using Window 7, and for DV capture software im using Wind DV and Exsate DV caputre live.
And thank you for answering.
Hi,
It seems your firewire output from player is dead. Only way I see is to let it repair it... Or you can use analog -> digital converter but it will not be lossless ...
Bernix -
Are EDIT MODE "Passive" and EDIT TERMINAL "DV"? Is DV SELECT set properly? Is the cable firmly plugged in at both ends?
if you have one working DV camera with firewire that works use that to capture tapes. it would appear the firewire port in the other device has died.
Thank you all very much for support. Yes i tried all terminals and cable plugged firmly in at both end but nothing is working. Particulary this DV player give me hard time always when plugged to PC unlike Canon camera, but seems this time more harder. So im not sure if this problem cuase as usuall or something new like from Window 7 signing in. However in Devices and Printers showing only Canon camera not Panasonic.
You might try switching to the legacy IEEE1394 driver (or vice versa, if you're already using it). Here are some instructions.
The only thing left is to try a different FireWire cable. And if that doesn't work, I'm inclined to agree that the Panasonic is broken.
hd video capture over firewire
By neuronetv in forum Newbie / General discussionsReplies: 7Last Post: 31st Oct 2015, 09:28 -
capture dv using firewire to h264, can it be done?
By pidro in forum Capturing and VCRReplies: 0Last Post: 1st Mar 2015, 21:41 -
best way to capture from firewire to USB?
By naldino in forum Capturing and VCRReplies: 8Last Post: 17th Sep 2014, 17:27 -
Firewire capture HD and netbook
By Cazz in forum Capturing and VCRReplies: 6Last Post: 10th Feb 2013, 07:59 -
Capture and convert -- firewire
By mister in forum Capturing and VCRReplies: 4Last Post: 30th Dec 2012, 09:28
