im dont k now too much about this, but i know for games looks better 60fps, in my case i have one hdpvr2 , my question its if really worth capture any channel to 60fps , i have directv, i ask this because i believe mayor channels are 30fps and not 60fps,
thank you
Hi,
IMHO the answer is simple. If the source is 60fps, then capture in 60fps, if source is 30fps then capture in 30fps. Pause the video and go to next frame, if the frame is same as previous (try on longer sequence), so capture at 30fps, if sequence of several frames in row is different (each of them) than capture at 60fps.
Bernix -
I think DirecTV has pay-per-view offerings broadcast at 1080p24, but I haven't heard of any network broadcasting progressive video at 30fps in the USA. 30fps channels are probably broadcast at 1080i or 480i, especially if they are from a network typically available over-the-air, like CBS, NBC, PBS, or ABC. The HD-PVR can capture 480i30, 720p60 and 1080i30 sources in their native resolutions. Pick whatever resolution you like best for output from the DirecTV receiver. If the DirecTV receiver correctly de-interlaces for 720p output, so that each field becomes a frame, 480i30 and 1080i30 channels will be output at 720p60.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
thank you , i just thinking to do 60 fps for old vcr games but maybe its not right.
for what i seeing imo, 60 fps get same visual effect in some videos with old ati stuff. im realizing its just playback with ati. -
HDPVR2 PS2 to HDTV Problems
By judgement0s in forum Capturing and VCRReplies: 4Last Post: 25th Jul 2015, 14:08 -
Hauppague HDPVR2: Is it working? Best I can do? Any input appreciated :)
By ThanksInAdvance in forum Capturing and VCRReplies: 1Last Post: 26th Apr 2015, 22:06 -
HDPVR2 won't capture 5.1 audio via HDMI
By kkiller23 in forum Capturing and VCRReplies: 6Last Post: 18th Oct 2014, 13:13 -
looking for help testing new HDPVR/HDPVR2/Rocket application
By sub3 in forum Capturing and VCRReplies: 19Last Post: 24th Aug 2014, 16:02 -
HDPVR2 and PS2
By Bizkit047 in forum Capturing and VCRReplies: 2Last Post: 21st Oct 2012, 16:40
