Hi!
GF GTX 1060 can't efficiently accelerate HEVC VP9 with software players like MPC-HC and Potplayer. In Potplayer I tried internal and external codecs like Lav filters with all options. The 4K videos droped frames and play the video on half FPS and very high CPU usage in software players, despite the video processing engine of the GPU worked in both payers.
Despite of this, the firefox and chrome browsers play the 4K videos (60 50 30 25p) perfectly with low CPU usage without frame drop.
How is it possible? Do the browser-based codecs have better GPU acceleration than software players?
Thank you for your reply!
CPU: Core i7-950 8GB ram. Op. system: Win 10 64bit.
Results 1 to 30 of 33
Almost everybody know, what do VP9 and HEVC codecs mean, I deal with digital videos since 1995. I use the newest Nvidia driver, but I tried earlier drivers of this year too. Nothing has changed. What is the problem with software players? So why can all browsers use the acceleration properly and efficiently?
Hi,
have you tried in Potplayer - preference - filter control - Open codec - Nvidia CUDA Decoder - Enable and in Video Decoder press ... next to HEVC: Build in Decoder same as in H.265 select here Nvidia CUDA decoder. But I think it depends also on video renderer, try default Video - Video renderer - (auto select recommended) Maybe it will helps you
Edit - so for you next to VP9 instead of HEVC or H265
BernixLast edited by Bernix; 14th Oct 2017 at 13:23.
maybe your processor is a showing signs of age.. 4k vid hevc need newer processors and gpus
This is the sample: the downloaded VP9 and H264 versions with 60 and 30p frame rates. https://www.youtube.com/watch?v=AuaLl2pII2Q
FYI Core i7-950 released june 2009 That's a good 8 years ago.. So it isnt new
Hi,
there must be some problem in your settings, because AFAIK your CPU does not support hardware acceleration Intel Quick Sync for H265. Try to utilize your 1060 CUDA cores for playback.
Bernix -
The Core i7-950 is still among the strong processors. An unused new Core i7-950 is still around 280$ in the shops.
https://www.cnet.com/products/intel-core-i7-950-3-06ghz/prices/Last edited by Stears555; 16th Oct 2017 at 04:13.
IT is not about the software playback option, since I've always used dxva2 copy-back. (because Cuda option caused problems in frame-step back). The video decoder engine of the card is active. I have an 1080p monitor and a Samsung UE55MU6102 UHD TV. The problem is the lack of GPU accelerated downscale and resize in software players. However the browsers have HW accelerated resize, so they can play the 4K content fantastic results from Youtube in both vp9 and AVC. When I connected the card to the UHD TV, and played the 4K videos in full screen in Potplayer and MPC-HC, the videos were fine, when I watched them in small (windowed mode) the problem appeared again.
Hi,
can I ask you what graphics card did you have before GTX 1060? When your videos played smoothly?
Thank you
Bernix -
Try to check rendering and processing tab too. And trade quality for performance too. Still don't know what graphics card did you use before, when everything was smooth.
And try dxva checker to get more info. I have only i5-6500 and only 1050ti but everything is playing smoothly. Probably there is some other bottleneck.
Bernix -
According to your screenshot you have a GT 1030, not GTX 1060.
I would reset madVR settings (to make sure you don't have any crazy settings on - madvr has lots of them in various menus. There's "restore default settings.bat" in madvr folder). For downscale algo Cubic should be good enough. "DXVA2" means the scaling will be left to the driver which may or may not be good. -
You are completly wrong. If I can play downloaded 4K@60 VP9 and AVC videos with the firefox and Chrome browsers without any problems from the SSD and Hard-disk, than the problem represented by the player. Maybe the software developers in big & rich companies are more professional than the third party cheap-boys who make these players and codecs, thus their products are more reliable.
Do you know what is "Feature Set H" aka "purevideo 8"? The HW must play even 8K videos in 8 10 12bit at 60fps.
Read about it here: https://en.wikipedia.org/wiki/Nvidia_PureVideoLast edited by Stears555; 16th Oct 2017 at 06:01.
In your screenshot in post #16 it shows "Active Hardware Accelerator: NVIDIA GeForce GT 1030".
You don't know the issue. PowerDVD can play 60 fps UHD material browsers also can play them with minimal HW usage. Potplayer VLC and MPC-HC can't do it. There are professionals in the video conversation topic, but somehow they tend to avoid software playing topic. In this thread I also get stupid answers from not-really serious teenager and junior age "gamer boys", who had no clue about digital videos. Who don't even own a real camcorder in their life just mobile phone cameras. (Maybe they have never held a camcorder in their hand)
gtx 1050 vs 1060 vs 1070 in encoding?
By dwaynek in forum Video ConversionReplies: 6Last Post: 26th Jan 2017, 09:16 -
Gtx 1060 vs gtx 150ti
By hdfills in forum Video ConversionReplies: 1Last Post: 13th Jan 2017, 10:18 -
Why has HEVC and VP9 so bad efficiency in a comparison with perseus V-NOVA
By Stears555 in forum Video ConversionReplies: 14Last Post: 14th Jun 2015, 11:56 -
NEW FFMPEG 2.1: native support for HEVC and VP9!!! :)))
By Stears555 in forum Video ConversionReplies: 3Last Post: 30th Oct 2013, 17:49 -
Where can I find VP9 encoders or a transcoder software which has VP9 too?
By Stears555 in forum Video ConversionReplies: 8Last Post: 10th Sep 2013, 16:51
