Closed Thread
  1. Hi
    I dunno whether this was the right forum, but it was as close as i could find.
    I need help on the playback of vcds on my playstation.
    I have a vcd adapter for the playstation and when i play vcds , its usually a bit strechted out horizontally so i cant see subtitles etc, but when i press the start button on the controller, it usually fixes it because it turns on PBC(i think thats wot it is, it allows forwarding, pausing etc).
    Here's the problem, i got this Karaoke vcd, and the words of the second line on the bottom are hidden because the screen is streched again, only this time, pressing start to turn on PBC ISNT WORKING!!!! Karaoke just isnt karaoke without the words!!!!! I've tried playing the vcd on the comp n it works fine, i can see the words, so i dont think its the disc (as in its not faulty).
    Can someone PLLLLLLLLLLLLZZZZZZZ help me?!?!?!!
    thank you very very much
    Lazerin
    ps I think PBC stands for PlayBack Control
