ive been messing with many programs and im trying to find the optimal settings for handbrake for converting 720p from 5000kbps down to 1000kbps without losing quality...currently ive tried mediacoder and vidcoder along with a handful of others but im limited on hard drive space so im trying not to go over 1000 kbps......any help is appreciated
Hi,
at first disable Peak framerate, set framerate to constant and same as source. Because of low bitrate (I suppose you will convert it to h264) then 2pass encoding 8 reference frames, Subme 9, bframes to 3-4. You can also test some denoise setting which will help compression in this case.
If you want to watch it only on computer then you can use h265 format with default preset (depending on your computer specs). But it takes more time but compression/quality is much much better. Change framerate as mentioned above. You get definitelly much more better quality.
And for both cases, if you have audio with high bitrate, you can change it to aac 112-128 kbps to spare space.
Bernix
Bernix -
Impossible.converting 720p from 5000kbps down to 1000kbps without losing quality
Lower the resolution for 1 Mbps. -
At 1000kbps, you're using a lower bitrate than VideoCD, which was 1/4 Standard Def and at-best looked similar to VHS. Now, H.264 is way more efficient than the MPEG-1 of VCD, but that'll only get you part of the way there. I recommend upping the average video bitrate to at least 1500 and setting Handbrake for 2-pass encoding.
I uploaded this clip from a TV show I recorded for a different thread, (for its subtitles). It's 720p, with a video bitrate of 1511 kbps.
Now if you're willing to reduce the resolution to 480p , 1000 kbps video could look as good as (or better than) DVD.
To reduce the resolution: in the Picture tab, set "Anamorphic" to "Automatic", the width to 720 & the height to 480. In newer versions (1+) of Handbrake, the Pixel Aspect Ratio will be set automatically.
Handbrake 1080i to 1080p or 720p settings?
By pipelineaudio in forum Newbie / General discussionsReplies: 10Last Post: 29th Mar 2017, 22:35 -
BEST Handbrake settings?
By alvis111 in forum Newbie / General discussionsReplies: 4Last Post: 12th Jan 2017, 21:06 -
Handbrake: converts 720p to 540 unwanted
By Valmont in forum Newbie / General discussionsReplies: 2Last Post: 28th Dec 2016, 09:43 -
Best Quality encoding from 1080p to 720p & 720p to 720p in Xvid4PSP?
By Odie111 in forum Video ConversionReplies: 8Last Post: 9th Jan 2016, 17:42 -
GOP Settings for HQ 720P Youtube Videos
By mdexter in forum Newbie / General discussionsReplies: 15Last Post: 4th Jul 2014, 20:47
