I have always used the default subme 7 setting.
Do the higher numbers actually give better quality output? I don't really see much difference from 7 and 9. I kind of think the 7 looks better as well or least I can seem to see tiny details a very slight bit better. The difference is so minor that even when zoomed in I can barely tell.
Whats with this setting and would using a subme setting of 11 even be beneficial?
You will not see much of a difference in normal situations, typical bitrate ranges. You will notice it more in very low bitrate range encoding scenarios
I tried both subme 7 and both subme 9 with a DVD at 1800kbps. The subme 9 seems to soften background items or certain things a bit. I don't really like that. If you zoom in, it appears more artifacts appear as well for the subme 9. Some also disappear or smooth out, but it looks like more appear to me. I'll just stick with subme 7.
Thanks for the information.
Concatenating 2 files with diffrent encoder setting (x264)
By ben45 in forum Video ConversionReplies: 25Last Post: 11th Oct 2016, 09:45 -
appended 2 mkv (x264) files with same setting but appended minutes are grey
By ben45 in forum Video ConversionReplies: 1Last Post: 7th Oct 2016, 09:35 -
x264 Mediainfo to MeGUI x264 Settings
By Arugen in forum Video ConversionReplies: 2Last Post: 13th Aug 2015, 01:14 -
show x264 command line output when using megui as x264 gui
By codemaster in forum Video ConversionReplies: 4Last Post: 12th Mar 2013, 10:35 -
x264: are ME settings conflictory to SUBME settings?
By deadrats in forum Video ConversionReplies: 1Last Post: 13th Dec 2012, 17:54
