Hi,
I followed DarkDreams encoding tutorial (need to sign in):
http://blackstaranime.forum.com.bz/t302-how-to-rip-a-dvd-to-your-hard-drive-for-encodi...ackup-purposes
http://blackstaranime.forum.com.bz/t310-how-to-use-avisynth
I ripped DVD with DVDDecrypter in IFO Mode, File Splitting = None, Chapter Information OGG
Then in MeGUI after all cropping and so on.
I was doing a test to see how long it takes to encode in MeGUI with these filters in the script (note: my video might not need all these):
HALO REMOVAL = HQDering(smoother=deen("a3d",1,9,2,2)
DENOISER = Deen("c3d",0,3,2)
ANTIALIASER = Maa()
CHROMA SHARPEN = MergeChroma(awarpsharp2(depth=4))
LINE THINNER = aWarpSharp(depth=3.5, blurlevel=1)
CHROMA SHIFTING = ChromaShiftSP(X=0.00, Y=0.00) # [X = Left/Right +/- Y = Up/Down +/-]
BRIGHTNESS, CONTRAST, SATURATION ADJUSTMENTS = Tweak(bright=0.00, cont=1.00, sat=1.00)
SHARPENER = LimitedSharpenFaster(ss_x=1.0, ss_y=1.0, strength=5, overshoot=0, undershoot=0, soft=0, edgemode=0)
The encoding setting was DarkDreams profile, you can download MeGUI with his settings and plugins:
http://blackstaranime.forum.com.bz/t321-encoding-software-you-will-need-for-my-tutorials
Anyway, its taking 1 hour to encode 5% of a 2h 8min movie.
5 frames per seconds.
My question, is this normal, i thought it would take max 5h for the whole movie and not 20h?
/Using a old laptop with i5 3210M + GeForce GT 640M
Thanks in advance
Those filters aren't very slow so your problem is probably the encoder settings.
Even if the encoder settings are different and all, how much can I expect to get from my current 5 FPS ?
I mean, are people having around 30 FPS or is it max x FPS no matter what or so?
Thanks in advance -
If you're using the x264 encoder -- there is a 100 fold difference in encoding speed between the ultrafast and placebo presets.
On my i5 2500K I get over 15 fps with a similar script, single threaded AviSynth, and x264 at the slow preset. With multithreaded AviSynth I get about 35 fps.Last edited by jagabo; 13th Oct 2017 at 17:34.
I had this in the script which cause the encode to be slow:
QTGMC(preset="slow", matchpreset="slow", matchpreset2="slow", sourcematch=3)
I removed Yadif and replaced it with the code.
Without it I get 11 FPS.
Thanks for the help -
And you don't think you should have mentioned that in your first post where you claimed to have listed all the filters used?
If you were to make available a small piece of your video, you'll probably get better suggestions on what to use, ones meant to fit your video and not just some generic ones you found online somewhere.
AviSynth script error on meGUI
By vancew90 in forum EditingReplies: 16Last Post: 16th Jan 2019, 06:42 -
Can't encode VC-1 videos with avisynth/MeGUI
By WAusJackBauer in forum Newbie / General discussionsReplies: 10Last Post: 15th Aug 2017, 04:00 -
MeGui + AviSynth alternative
By shorto in forum EditingReplies: 17Last Post: 3rd Nov 2014, 15:12 -
Problem using AviSynth scripts with MeGUI
By yaston in forum Video ConversionReplies: 6Last Post: 5th Oct 2014, 22:24 -
MeGUI and aviSynth
By Slind in forum Video ConversionReplies: 15Last Post: 9th Nov 2013, 19:28
