  1. How do you find the code for streamlink
    This is a livestreamer code
     livestreamer "hds://cdn.rasset.ie/hds-vod/2017/0919/20170919_rtetwo-schizophre_cl10777926_10777929_ip000062899_260_drm_/manifest.f4m" best -o RTE.flv
    What would it be if using streamlink
    I am experimenting to see if streamlink will work and do not really know what i am doing but have to try
  2. Hi ,
    replace ( only ) livestreamer by "D:\python\Scripts\streamlink.exe" ( for example ) .
    Cheers .
    JE SUIS CHARLIE !!!
  3. Originally Posted by aazerty View Post
    Hi ,
    Cheers .
    Thanks. Wouldn't that be if python was on a D drive? I have portable streamlink where is scripts?
  4. Hi ,
    What I can say :
    1) I am under Win XP sp3
    2) I haven't a portable version for streamlink
    3) Python (v 2.712) is installed on disk "D"
    4) My batch file
    @echo on
    python -m pip install --upgrade pip
    pause
    "D:\python\Scripts\pip.exe" install -U streamlink
    pause
    "D:\python\Scripts\easy_install-2.7.exe" -U streamlink
    pause
    "D:\python\Scripts\pip.exe" install requests
    "D:\python\Scripts\pip.exe" install websocket-client
    pause
    :fin
    If your "streamlink" is in the path ; in the command replace "livestreamer" by "streamlink" .
    Cheers .
    JE SUIS CHARLIE !!!
  5. Originally Posted by aazerty View Post
    Hi ,
    What I can say :
    4) My batch file
    @echo on
    pause
    pause
    pause
    pause
    :fin
    Cheers .
    Thanks. my path to streamlink is
    C:\Users\username\Downloads\PORTABLE\STREAMLINK\st reamlink-portable-master\Streamlink for Windows (Compiled)\Releases\Streamlink.exe
    i do not understand why you ave the batch file
    EDIT: I installed the exe not the portable on a virtual windows and it does work by replacing livestreamer with streamlink so thanks for your help
    Unfortunately it will not work with tv3.ie
  6. Hi ,
    > i do not understand why you have the batch file
    As I am under XP , streamlink's portable version doesn't works .
    The way ( for me ) is to install streamlink in python's directory .
    Using this batch , I am sure having the last good state .
    Cheers .
    JE SUIS CHARLIE !!!
  7. Originally Posted by aazerty View Post
    Hi ,
    Cheers .
    OK isee it now. Thanks
