there is a video where i lowered the gamma because it looks better that way
"ColorYUV(cont_y=-7, cont_u=0, cont_v=10,gamma_y=-60)'
the only problem is that blacks turn into too black resulting in some detail loss on black areas (anime)
lets say black gloves for example become just charcoal
in short is there a way to crank up the gamma only for black colors?
Have you tried Levels?
(0, 1.0, 255, 0, 255, coring=false)
The zeros are the black input and output levels and the 255's are the whites, and 1.0 is the default gamma.
If you reduce the gamma and the blacks get too dark you can compensate by raising the black level a little.
(0, 1.0, 255, 8, 255, coring=false)
or maybe try a standard limited to fullrange levels conversion (or something in between) rather than mess with the gamma? I find stretching/reducing the luminance range is generally better than messing with the gamma on it's own.
(16, 1.0, 235, 0, 255, coring=false)
or ColorYUV(Levels="TV->PC")
or try YLevels(). It's very much like the Avisynth Levels function but I think it adjusts chroma too (sometimes that's better, and sometimes not, so it pays to compare the two). http://avisynth.nl/index.php/Ylevels -
There's SGradation, which can be use in combination with gamma, brightness and contrast.
It's a kind of "second-order gamma"(EDIT YLevels.avsi::YLevelsS does something very similar)Code:# output luma with gamma < 1.0 # ^ # 255+ + # | + # | + # | + # | + # | + # | + # 128+ +++ # | + # | + # | + # | + # |+ # |+ # 0+-------------+-------------+> input luma # 0 128 255
This will prevent darks from dropping below Y=16:
You may have to adjust the values a little.Code:ColorYUV(levels="TV->PC").ColorYUV(cont_y=-7, cont_u=0, cont_v=10,gamma_y=-60).ColorYUV(levels="PC->TV")
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 08:21 -
[Help] Problems with the "Title Button" in the "VTS ROOT" and "VTS Normal"
By kirous in forum Authoring (DVD)Replies: 8Last Post: 1st Nov 2014, 13:31 -
the "-intra" command in ffmpeg.exe affects encoding "-vcodec copy" mode?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 23rd Oct 2013, 16:53 -
colorYUV levels="PC->TV" vs "TV->PC"
By dphirschler in forum RestorationReplies: 5Last Post: 4th Apr 2013, 11:39 -
Avisynth ColorYUV Gamma is doubling the encoding bitrate, please help
By VideoFanatic in forum RestorationReplies: 43Last Post: 15th Feb 2013, 11:41
