Hello,
I am discovering VSDC.
The last section of the video I am working on contains a serious fastforward section (1000%). As a result the preview is inusable, it just doesnt' work on that section. So to make things fit I have to export the video to view it, then make adjustments in VSDC, then re-export etc. It is a bit tedious, so my question is :
Is it possible to export only part of the video in VSDC ?
I have tried, but have not found the solution yet.
Many thanks for your help !!!
Johan
I imagine if you select the whole track and copy it to clipboard, delete the sections you don't want, then export the remainder, you have your final exported clip.If you then paste the whole track back and delete the clips, you're back where you started. Don't use it, so I don't know if there is a way to isolate a section.
Edit: most editors can turn a track on or off (include/exclude). Maybe just copy the clips you need to a new track and exclude the main track, and render.
This seems to be 'the' new free NLE. Will have to check it out over the coming weeks. When time permits.Last edited by transporterfan; 11th Oct 2017 at 18:26.
Hi transporterfan, many thanks for your idea. It is excellent, I just applied it, so I could export smaller files and finetune the timing. All the best to you !
VSDC video editor export problem: How do I cut the unwanted extra duration?
By T111 in forum EditingReplies: 1Last Post: 7th Mar 2017, 19:08 -
VSDC Free Export Problems
By swede1128 in forum Newbie / General discussionsReplies: 1Last Post: 23rd Dec 2016, 13:28 -
VSDC video editor shows image on preview, but when I export the video
By elisape in forum Newbie / General discussionsReplies: 2Last Post: 20th Oct 2016, 04:51 -
VSDC Exporting Issues - Can Someone help me export?
By INsupps in forum EditingReplies: 8Last Post: 12th Nov 2015, 13:15 -
How to convert *.mkv to *.avi with copy video part and re-encode audio part
By pxstein in forum Video ConversionReplies: 13Last Post: 1st Aug 2014, 11:24
