Hello,
Can someone please help me with building the batch script?
I'm trying to create a batch process for my video files, i have mkv files with embedded subtitle and i want to extract a specific language subtitle to srt file and remove all subtitles within that mkv file, i also want to preserve the creation/modified date of the file.
Here are the steps for my need:
- Search within a folder with sub-folders all the mkv files
- Check every mkv file for subtitles
- If subtitles exists, search for Hebrew Subtitles
- If Hebrew subtitles exists, than extract it to .srt file
- When the subtitle been extract, mux the mkv file to remove all embedded subtitles from that mkv file
- Remove old file
- Rename new file with the original name
- Preserve creation/modified date of the file
i've searched the forum and found a script that i can use, so i tried to modify it for my purpose but unfortunately i'm getting a lot of errors and i don't have the knowledge to fix it.
this is my modified script:
This is my folders structure:Code:REM @ECHO OFF REM // ======================= REM || Batch Subtitle Muxing REM || for MKVmerge REM || v0.4-20150511 by drudge REM \\ ======================= REM @@ This batch script will scan the provided directory (or current folder) REM @@ for video files, attempt to match them with subtitle files, REM @@ and mux them using the MKVmerge command line. REM // ---- ---- ---- ---- REM || USER CONFIGURATION REM // full path to mkvmerge.exe REM SET muxpath=C:\Program Files\MKVToolNix\mkvmerge.exe REM // full path to mkvmerge.exe REM SET extractpath=C:\Program Files\MKVToolNix\mkvextract.exe REM \\ -- -- -- -- -- REM // full path to unrar program, make sure to include switches REM SET rarpath=C:\Program Files\7-Zip\7z.exe REM SET rarcmd=e REM \\ -- -- -- -- -- REM // output path (with trailing slash) REM ++ leave blank for working directory SET outputdir= REM @@ default: SET "outputdir=" REM \\ -- -- -- -- -- REM // prepend text to output filename REM ++ REQUIRED if outputdir is left blank SET filesuffix=-new REM @@ blank: SET "filesuffix=" REM \\ -- -- -- -- -- REM || END USER CONFIG REM \\ ---- ---- ---- ---- REM -- editing below this line should be done precisely. (here thar be dragons) REM =========================================================================== REM @@ simple counters SET /A "mc=0" SET /A "me=0" REM @@ default working path SET wp= REM @@ optional working path via argument IF EXIST "%~1" SET wp=%~1 REM @@ ready steady go! CLS ECHO =========================================================================== REM @@ attempt to use custom setting for output path IF EXIST "%outputdir%" ( REM @@ user has provided output path ECHO == User Setting -- Output to: [%outputdir%] ) ELSE ( REM @@ no custom setting, check for suffix IF [%filesuffix%]==[] ( ECHO @@ ERROR: empty [filesuffix] setting requires [outputdir] to be set SET /A me+=1 GOTO:done ) REM @@ use working path for output SET outputdir=%wp% ) FOR /r %%H IN ("%wp%") DO ( REM @@ because "." doesn't tell us where we are ECHO == Scanning [%%~dpfH\] for video files... ) :GETFILES FOR /r %%I IN ("%wp%*.mkv") DO ( REM @@ found a video file, now check for subtitles CALL:SUBSEARCH "%%~I" ) GOTO:done :SUBSEARCH FOR /f %%A in (' mkvmerge -i "%~dpnx1" ^| FIND /c /i "subtitles" ') DO ( IF %%A==0 ( ECHO @@ ERROR: "%~nx1" has no subtitles GOTO:eof ) ELSE ( ECHO "%~nx1" has subtitles, searching for Hebrew subtitles. FOR %%B in (' mkvmerge -F verbose-text -i "%~dpnx1" ^| FINDSTR /i /r /c:"subtitles.*heb" ') DO ( IF %ERRORLEVEL% EQU 0 ( SET substring=mkvmerge -F verbose-text -i "%~dpnx1" ^| FINDSTR /i /r /c:"subtitles.*heb" CALL SET track=%substring:~9,1% ECHO HEBREW Track ID: %track% CALL SET line= %track%:"%~n1.heb.forced.srt" CALL :SUBEXTRACT ) ELSE ( ECHO %~nx1 do not have Hebrew subtitles. CALL :MUXIT ) ) ) ) :SUBEXTRACT setlocal enabledelayedexpansion mkvextract --ui-language en tracks "%~dpn1.mkv" !line! ||(ECHO Demuxing error!&GOTO:eof) endlocal CALL:MUXIT :MUXIT REM @@ we've made it! SET /A mc+=1 REM @@ now we let mkvmerge work its magic ECHO | SET /p muxdone="++ Muxing: (%mc%) [%~n1%~x1]" mkvmerge -o "%outputdir%%~n1%filesuffix%%~x1" --no-subtitles --language 0:eng --default-track 0:yes --language 1:eng --default-track 1:yes "%~1" --track-order 0:0,0:1 ECHO ..complete REM @@ success! REM @@ remove old file ECHO removing old file... IF EXIST "%outputdir%%~n1%filesuffix%%~x1" if NOT ERRORLEVEL 1 ( DEL "%~f1" REN "%outputdir%%~n1%filesuffix%%~x1" "%%~nx" GOTO:eof :done ECHO == Finished Processing: %mc% completed / %me% errors ECHO =========================================================================== REM @@ game over, man pause
Movies
├─Movie_abc [...]
│ ├─Movie_abc.mkv
├─Movie_def [...]
│ ├─Movie_def.mkv
├─Movie_ghi [...]
│ ├─Movie_ghi.mkv
TV Shows
├─Series _abc [...]
│ ├─Season 1
│ ├─ Episode_abc.mkv
│ ├─ Episode_def.mkv
├─Series _def [...]
│ ├─Season 1
├─Series _ghi [...]
│ ├─Season 1
Thank in advanced for anyone that can help me.
I always get the error:
i can't figure what is the problem with the ELSECode:'ELSE' is not recognized as an internal or external command, operable program or batch file.
Thanks for all the help...
But i`ve succeeded to build my own bash script, so if anyone need it (run it on linux).
Code:#!/bin/bash ## 2017-10-20 By Idan Bush ## # Check if tools are exists hash mkvmerge 2>/dev/null || { echo >&2 "Error: Command mkvmerge not found"; exit 1; } hash mkvextract 2>/dev/null || { echo >&2 "Error: Command mkvextract not found"; exit 1; } extract_subtitles_from_file() { local mkvfilename="$1" local subline="$2" filename=${mkvfilename##*/} # Get track id of subtitle tracknumber=`echo $subline | egrep -o "[0-9]{1,2}" | head -1` # Define the subtitle filename format subfilename=${mkvfilename%.*}".heb.forced.srt" subname=${subfilename##*/} if [ -f "$subfilename" ]; then echo "[ SKIP ] '$subname' already exists." else echo "[EXTRACT] '$filename' -> '$subname'." mkvextract tracks "$mkvfilename" $tracknumber:"$subfilename" `chmod a+rwx "$subfilename"` fi } remove_subtitles_from_file() { local mkvfilename="$1" # Extracting filename filename=${mkvfilename##*/} # Get base name for new file newmkvfilename=${mkvfilename%.*}"-new.mkv" # Extracting filename newfilename=${newmkvfilename##*/} # Remving all subtitles echo "[ REMUX ] Removing all subtitles from '$filename'." mkvmerge -o "$newmkvfilename" --no-subtitles --language 0:eng --default-track 0:yes --language 1:eng --default-track 1:yes "$mkvfilename" --track-order 0:0,0:1 # Copy modified date from original file echo "[ COPY DATE ] Modified date copied." touch -d "$(date -R -r "$mkvfilename")" "$newmkvfilename" # Delete original file echo "[ DELETE ] Deleting the file '$filename'." rm "$mkvfilename" # Rename new file with original file echo "[ RENAME ] '$newfilename' > '$filename'." mv "$newmkvfilename" "$mkvfilename" `chmod a+rwx "$mkvfilename"` } rename_subtitles() { local subfilename="$1" # Extracting filename filename=${subfilename##*/} if [[ "$subfilename" != *".heb.forced.srt" ]] && [[ "$subfilename" != *".heb.srt" ]] && [[ "$subfilename" != *".he.forced.srt" ]] && [[ "$subfilename" != *".he.srt" ]]; then # Removing extension subname=${subfilename%.*} # New subtitle name newsubname="$subname.heb.forced.srt" # Extracting filename newfilename=${newsubname##*/} # Renaming echo "[ RENAME ] '$subfilename' > '$newsubname'." mv "$subfilename" "$newsubname" `chmod a+rwx "$newsubname"` elif [[ "$subfilename" == *".heb.srt" ]] || [[ "$subfilename" == *".he.srt" ]] || [[ "$subfilename" == *".he.forced.srt" ]]; then # Removing extension subname=${subfilename%%.he*} # New subtitle name newsubname="$subname.heb.forced.srt" # Extracting filename newfilename=${newsubname##*/} # Renaming echo "[ RENAME ] '$subfilename' > '$newsubname'." mv "$subfilename" "$newsubname" `chmod a+rwx "$newsubname"` else echo "[ SKIP ] There is no subtitle that need renaming" fi } process_file() { local mkvfilename="$1" mkvdir=${mkvfilename%/*} mkvname=${mkvfilename%[*} # dt=$(date '+%d/%m/%Y %H:%M:%S'); echo "$(date '+%d/%m/%Y %H:%M:%S')" ==================== BEGIN ==================== find "$mkvdir" -type f -name "${mkvname##*/}"*.srt | while read subfilename do rename_subtitles "$subfilename" done mkvmerge --identify-verbose "$mkvfilename" | grep 'subtitles' | while read subline do mkvmerge --identify-verbose "$mkvfilename" | grep 'subtitles' | grep 'language:heb' | while read subline do extract_subtitles_from_file "$mkvfilename" "$subline" done remove_subtitles_from_file "$mkvfilename" done echo "$(date '+%d/%m/%Y %H:%M:%S')" ==================== DONE ==================== } process_dir() { local DIR="$1" find "$DIR" -type f -name '*.mkv' | sort -n | while read mkvfilename do process_file "$mkvfilename" done } # If no directory is given, work in local dir if [ "$1" = "" ]; then process_dir "$PWD" # If parameter is file, extract only subtitles for that file elif [ -f "$1" ]; then process_file "$1" # If parameter is directory, process directory recursively else process_dir "$1" fi
MKVMERGE Batch Muxing multiple audio and subtitle tracks?
By jahob000 in forum Newbie / General discussionsReplies: 38Last Post: 30th May 2023, 20:13 -
MKVmerge batch remuxing and removing subtitles?
By TE16 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Sep 2017, 07:55 -
How to embed subtitles into mkv STEP BY STEP using MKVMERGE and MKVEXTRACT
By lelouch283 in forum SubtitleReplies: 30Last Post: 23rd Jun 2017, 15:04 -
How to extract only forced subtitles with a batch muxing using mkvmerge?
By davboc in forum EditingReplies: 1Last Post: 1st Jul 2016, 14:28 -
Mkvmerge batch muxing with some custom attributes
By Pegla in forum Newbie / General discussionsReplies: 3Last Post: 13th Jan 2016, 02:26
