I'm trying to recover a corrupted mp4 file. The recording unit was disconnected prior to the end of writing. Using Recover_mp4.exe, I entered "recover_mp4.exe good.mp4 --analyze" and recieve the following:
Cannot find 'avcC' atom (AVCDecoderConfigurationRecord) or
Cannot find 'hvcC' atom (HEVCDecoderConfigurationRecord) in 'good.mp4'
Be sure your file is MP4/MOV with the codec MPEG-4 part 10 (AVC/H.264) or
MPEG-4 part 15 (HEVC/H.265).
This program does not support video format 'mp4v'.
File 'audio.hdr' created succesfully
Video statistics:
Sample Size: Min 0x9f, Avg 0x9f, Max 0x13e2c
Samples Per Chunk: Min 15, Avg 15, Max 15
Sound statistics:
Sample Size: Min 0x200, Avg 0x200, Max 0x200
Samples Per Chunk: Min 22, Avg 24, Max 26
Count 12848, [21 1c 4f] Fixed Size 0x200
Count 91304, [21 1c 53] Fixed Size 0x200
Count 18689, [21 1c 54] Fixed Size 0x200
ERROR: Unsupported video format !!!
Any help is appreciated. Thanks.
Results 1 to 10 of 10
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp41/mp42)
File size : 446 MiB
Duration : 43 min 40 s
Overall bit rate mode : Constant
Overall bit rate : 1 429 kb/s
Video
Format : MPEG-4 Visual
Format profile : Simple@L5
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : mp4v-20
Source duration : 43 min 40 s
Bit rate mode : Constant
Bit rate : 1 234 kb/s
Nominal bit rate : 2 000 kb/s
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 29.970 (30000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.134
Stream size : 385 MiB (86%)
Source stream size : 385 MiB (86%)
Audio
Format : AAC
Format profile : LC
Codec ID : mp4a-40-2
Bit rate : 192 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Stream size : 60.0 MiB (13%) -
Mpeg-4 visual is associated with mpeg-4 part 2, typically Xvid and Divx.
It looks as if the program you're trying to use is intended for usage with mpeg-4 part 10, typically AVC/ H.264 video
and, apparently, HEVC
If the file is not too big, you're welcome to post the whole file and somebody will investigate further -
and the bad. I have more like these so I'm interested in the solution itself.
Try this to repair your files, I was able to get a result after
feeding it the good and the bad you provided.
https://www.videohelp.com/software/Video-Repair-Tool -
Ellinorwilliam, thank you for the suggestion. I followed the advice of davexnet using the Video-Repair-Tool with good results. (Thanks davexnet and sorry I didn't thank you sooner). After using that software, I ended up with a working file but it still wasn't recognized by Premiere. I then used Handbrake to convert it to a new mp4 and that seemed to be acceptable to Premiere (whatever).
Anyway, thanks again folks. You saved a bunch of important underwater research video.
-DChosid -
Btw, recover_mp4 is not free anymore, from what I've gathered. Here, https://www.videohelp.com/software/recover-mp4-to-h264 leads to http://slydiman.me/eng/mmedia/recover_mp4.htm website, and on his website, he says that the tool is now updated, all online, and has moved to https://restore.media/ website. Perhaps they own the service now
VirtualDub error: Video Compressor error: The source image format is not
By maddie in forum Capturing and VCRReplies: 1Last Post: 26th Apr 2015, 11:12 -
Unsupported video resolution
By Din Viesel in forum Newbie / General discussionsReplies: 17Last Post: 24th Apr 2014, 03:23 -
Long Capture unsupported format damaged file
By federomano in forum Capturing and VCRReplies: 5Last Post: 29th May 2013, 10:15 -
Samsung TV Unsupported Video Data
By Dam18 in forum Video ConversionReplies: 4Last Post: 14th Jan 2013, 16:39
