Results 1 to 9 of 9
    Jun 2013
    I have a mpeg2/AC3 file that I've put in a mkv container using Videoredo.. It plays fine on my PC & Kodi but I need to send a version of it to a friend with a Mac..
    I tested it with my PC version of quicktime but it won't play.. What do I need to do?
    Is there a way without transcoding video? I tried videoredo and saving it to mpeg2 mp4 but that won't play in quicktime either..
    Any advice? Thanks..
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    1/ Most Mac users know that QuickTime Player isn’t the ultimate media player that it once tried to be. It seems many users know to install a secondary media player, like VLC.
    2/ QuickTime Player v10 for Mac is definitely not feature-synced with QuickTime Player v7.7.9 for Windows. You can’t conclude much from playing on the other platform.
    3/ A DVD compliant .mpg file with mpeg-2 video and ac3 audio should play fine in QuickTime Player (v10.x) for Mac without the need for plugins. Feel free to send me a short test clip.
    Jun 2013
    He's in the process of downloading it now. I appreciate your offer to take a look at it but it might be easier to wait and see if he can play it first..
    Here are the mediainfo mp4 container specs:
    (My VLC choked on the m2v1)
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt 0000.02 (qt )
    File size : 4.40 GiB
    Duration : 1 h 35 min
    Overall bit rate : 6 583 kb/s
    Writing application : Lavf54.63.104
    Video
    Format : m2v1
    Codec ID : m2v1
    Bit rate : 5 999 kb/s
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Frame rate mode : Variable
    Frame rate : 29.970 (30000/1001) FPS
    Minimum frame rate : 29.970 FPS
    Maximum frame rate : 30.000 FPS
    Standard : NTSC
    Bits/(Pixel*Frame) : 0.579
    Stream size : 4.01 GiB (91%)
    Language : English
    Menus : 4
    Audio #1
    Format : AC-3
    Format/Info : Audio Coding 3
    Codec ID : ac-3
    Duration_LastFrame : -32 ms
    Bit rate mode : Constant
    Bit rate : 384 kb/s
    Channel(s) : 2 channels
    Sampling rate : 48.0 kHz
    Bit depth : 16 bits
    Compression mode : Lossy
    Stream size : 263 MiB (6%)
    Language : English
    Default : Yes
    Alternate group : 1
    Menus : 4
  4. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    That is neither MKV nor MPEG-PS. Did you make it a MP4 this last time?
    m2v1 seems unexpected, though.
    Jun 2013
    That's what VideoRedo did when I picked the mpeg2 mp4 save as format type.. here's the media info for the original mkv
    Format : Matroska
    Format version : Version 4 / Version 2
    File size : 4.39 GiB
    Overall bit rate : 6 578 kb/s
    Encoded date : UTC 2017-10-06 22:02:40
    Writing application : mkvmerge v16.0.0 ('Protest') 64-bit
    Writing library : libebml v1.3.5 + libmatroska v1.4.8
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@Main
    Format settings, BVOP : Yes
    Format settings, Matrix : Default
    Format settings, GOP : M=3, N=15
    Format settings, picture structure : Frame
    Codec ID : V_MPEG2
    Codec ID/Info : MPEG 1 or 2 Video
    Bit rate mode : Variable
    Maximum bit rate : 9 000 kb/s
    Width : 720 pixels
    Height : 480 pixels
    Frame rate mode : Constant
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Bottom Field First
    Time code of first frame : 00:00:00;00
    Time code source : Group of pictures header
    GOP, Open/Closed : Closed
    Default : Yes
    Forced : No
    Jun 2013
    I also have the authored DVD files if that enables an easier work flow...to Mac.
  7. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Doesn’t VideoReDo have a ‘normal’ MPEG-2 output profile? MPEG Program Stream (.mpg): mpeg-2 video + ac3 audio.
    Jun 2013
    I would like to retain chapter marks.. Hence the mp4 mkv containers.
  9. Zip the DVD folder and send the full movie, ready to burn.
    http://www.dummies.com/computers/macs/how-to-zip-and-unzip-files-on-your-mac/
    Or just view the file; in either case, have your friend use MPlayer to watch them.
    Not sure about MPlayers ability use chapters.
