Hi all,
As an utter noobie, would like a bit of help. I found these instruction online http://www.digitalfaq.com/guides/video/capture-avi-virtualdub.htm#iuvcr
In it it saysCan anyone advise what the PAL fps would be for this please?VirtualDub comes with very low quality default settings, so most settings need tweaking. Change from 15.00 fps to 29.97 fps (full NTSC).
In the Audio settings:
Is this the same for PAL ?Audio settings. Go to the Audio menu, and go down to Compression. A new will open with the audio settings. Change it to PCM format using 48.000 kHz 16-bit stereo. Click Save As and give the new settings a name. I choose “DVD 48k” for mine. Click OK. You should now notice the audio level is 48K/16/s in the lower-right corner of the capture console.
If not what wold be the correct settings?
I eventually intend to edit in Sony Vegas and burn to DVD.
I'll be working on a Virtual Machine using Windows XP and have installed HuffYUV on the XP too. I am transferring video/Audio from my 8mm camcorder via a Belkin F5U205 importer.
Thanks in advance.
H all having rather a lot of issues.
Using the instructions in the link above this is what is wrong.
- I go to the Capture Settings and set it to 25 and click OK but this never saves.
- I go to Audio Settings and ther is no PCM formet.
- I go to Standard Video settings and the Overlay is greyed out as is the next step Format.
- I go to Video > Source and it is greyed out so cannot select it
I have VirtualDub version 1.10.4 installed (The instructions in the link are for 1.5.1 but cannot imagine they are different).
I have installed HuffYUV (downloaded it from here and right click installed it).
When I go to Video > Video Sources > No Video Sources.
What is wrong .. help please ? -
Why are you using a 15-year-old Virtualdub capture guide? Go here and start with something new: http://www.digitalfaq.com/forum/video-capture/7427-capturing-virtualdub-settings.html
If you don't know that PAL video tape is 25fps, you need to do a little more research.- My sister Ann's brother -
settings for virtualdub to capture VHS-C
By rob99 in forum Capturing and VCRReplies: 8Last Post: 9th Apr 2016, 09:37 -
Hauppauge Live 2 best proc amp settings in Virtualdub?
By premiumcapture in forum Capturing and VCRReplies: 4Last Post: 5th May 2015, 08:12 -
Virtualdub HD Capture Settings
By angelroj7 in forum Capturing and VCRReplies: 1Last Post: 24th May 2014, 10:02 -
Virtualdub - Capture Settings and Tweaking
By zerowalker in forum Capturing and VCRReplies: 2Last Post: 17th Feb 2014, 20:01 -
Virtualdub deshaker starting settings.
By cabruss in forum Newbie / General discussionsReplies: 0Last Post: 17th Nov 2012, 06:19
