Hi,
like title says, my canon hv30 will record for maybe 5 minutes or so and then it just shuts down/turns off. Battery has charge and if i remove it and re-insert, the cam will turn back on. when i start recording again, it does so for a few minutes, then shuts off again. same happens with a different battery.
i don't see that it would have any bearing, but i have no more blank tapes, so was trying to lay black over a couple of them for a second pass. doesn't matter what previously recorded tape i try, same problem.
as far as playing those previously recorded tapes back through the cam, no issue
i've had cam a few years now, likely used it somewhat less than most folks would, and it's in great condition, otherwise
anyone have an idea?
thanks
phil
does the camera have an AC adapter ?? try running it with an ac power adapter.
try not recording black. see if it will record over a previous tape without a problem. HDV doesn't have to be recorded over a "blacked tape" to work fine.
thnx for the responses, sorry it took awhile to get back, live in northern Cal , dealing with the fires.
yes, had tried recording normally (not black), as well, same issue.
will def try with it plugged into AC -
so, hmm, interesting, if it's plugged into AC, it continues to record to end of tape.
but battery display shows batts have lots of juice... -
could be dirty/oxidized contacts on batteries or camera contacts. or just bad batteries, they don't last more than a few years before deteriorating.
That's a sure sign that your battery no longer holds it's charge. Time for a new one.
Occasional stutters when playing HDV files using VLC from Canon HV30 in 30p
By XperienceD in forum Software PlayingReplies: 5Last Post: 8th Jan 2016, 18:42 -
Canon HV30 MiniHDV - to Mac 1080i format?
By neltek in forum MacReplies: 3Last Post: 9th Jul 2014, 23:56 -
Canon VIXIA HV30 is sometimes recognized
By bmklawt in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 6th Jun 2014, 09:35 -
capture through hdmi on canon HV30
By perik in forum Capturing and VCRReplies: 1Last Post: 1st Aug 2013, 07:22 -
ADVC-110 vs Canon HV20, HV30, HV40
By jan3sobieski in forum Capturing and VCRReplies: 1Last Post: 3rd Nov 2012, 10:50
