Hi,
I've noticed my mpeg2 video is interlaced and the only decoder that I've seen that fixed it properly was the LAV codec in MPC-HC.
I've set it as top-field first and deinterlacing as aggressive.
I want to use the LAV decoder in virtualdub as decoder. But I haven't found a way yet.
I've tried adding the deinterlace filter with different settings and the one closets to LAV decoder was this
https://gyazo.com/34c9d5f54e72dd77031265a93a847ae6
But it still shows signs off interlacing, but it in the lav decoder it almost or completely disappears.
LAV decoder settings in MPC-HC: https://gyazo.com/cda372b35a9c24378bfe415efc7febd9
Does someone know how to add the LAV decoder to Virtualdub, is this possible?
Regards, Patriek
Results 1 to 9 of 9
AnonymousGuest
If I were you, I would build a .GRF file in Graphstudio and then use it in an Avisynth script through DirectShowSource()
http://avisynth.nl/index.php/DirectShowSource#Opening_GRF_files -
Using the directshow plugin for VirtualDub will let you use LAV if you have it installed as Directshow filters. But the best deinterlacing by far is QTGMC in AviSynth. Blending fields is one of the worst deinterlacing methods. I wasn't impressed with MPCHC's LAV aggressive deinterlacing. Just learn to use AviSynth and QTGMC. You'll be glad you did.
And, is your video really interlaced? It may be telecined film, which should be inverse telecined, not deinterlaced. -
I've been googling now for 30 minutes and I can't find the directshow plugin for virtualdub,Using the directshow plugin for VirtualDub will let you use LAV if you have it installed as Directshow filters.
Or am I missing something here?
I'm using the 64bit version btw. -
I've finished making the grf file. But I can't open the avs file I've created for vdub. I'm kinda new with avisynth coding itself.
Do you mean I've to make a .avs document with only this code?:
Else can you send me a example code?Code:Directshowsource(D:\Folder\Thegrffile.grf)
I would still recommend to analyze this video for its field structure to find the optimal native AviSynth filter to either revert a telecine or deinterlace a lot better than real-time speed oriented DirectShow filters ever could. But first, discover which tool is correct for your specific material.
Adding DirectShow usually means losing control over quality retention.
MadVR vs LAV
By snadge in forum Software PlayingReplies: 26Last Post: 13th Dec 2019, 15:47 -
K-lite and LAV video decoder made a mess in my PC
By friendly_jacek in forum Newbie / General discussionsReplies: 6Last Post: 2nd Sep 2015, 15:13 -
Do I need LAV filters?
By Yanta in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jan 2015, 04:01 -
LAV Video Decoder crashes when playing i420
By tyee in forum Software PlayingReplies: 0Last Post: 1st Dec 2014, 12:04 -
VirtualDub: how to set as default "swap field" for Internal MJPEG decoder?
By marcorocchini in forum Newbie / General discussionsReplies: 9Last Post: 27th Sep 2014, 13:01
