Hi ****
because ffprobe interlaced_frame and mediainfo is too slow to determine if the video source is progressive or interlaced.
I wonder if is there a faster way , thanks
Results 1 to 14 of 14
it's enought something that determine if progressive or not, but more quickly. Only detect if the source is flagged as progressive or not
Does this take too long?
Code:Mediainfo.exe --Inform=Video;%%ScanType%% "%~1" > temp.tmp set /p scantype=<temp.tmp echo Mediainfo reports: scantype=%scantype% pause
thank you cat
I have download mediainfo CLI 0.7.99 64bit: too long? 40 seconds to analyze 168 MXF video files: maybe is not the better but is acceptable
Maybe you should analyze those files using all CPU cores instead of one? Something tells me that you are analyzing those files one by one.
sorry I'm a Cat
my english is bad, my brain is bed
This is the batch that I use, but I'm thinking I'm analyze one by one the original source:
Code:@rem unless otherwise specified for debugging reasons turn echo off @if "%EMode%"=="" Set EMode=ON @ECHO %EMode% @ECHO off if exist "%cd%\tempTotale" del /f /q "%cd%\tempTotale" if exist "%cd%\tempTotale" rd /s /q "%cd%\tempTotale" /s SetLocal DisableDelayedExpansion Set "EXTLIST=*.mxf" Set "DoPop=0" Set "ARGLVL=0" Set "FileName-DQ=" set "DestFolder=." Set "WorkFolder=%DestFolder%" rem process the arguments one by one :ARGS color rem if there are no further arguments then exit the batch. if [%1]==[] ( if "%ARGLVL%"=="0" ( CALL :GetTargetName EndLocal pause ) goto :eof ) rem wildcard processing Set "FileName=%~1" if "%FileName%"=="" ( SHIFT goto :ARGS ) rem if the argument doesn't exist in the file system in any form skip it. if NOT EXIST %1 ( SHIFT goto :ARGS ) if NOT [%1]==[] if NOT "%FileName:^*=%%FileName:^?=%"=="%FileName%%FileName%" ( for %%w in (%1) DO ( Set /a ARGLVL+=1 CALL :ARGS "%%~fw" Set /a ARGLVL-=1 ) SHIFT goto :ARGS ) Set "FileName=" rem Set search/recursion variables Set "Pattern=%EXTLIST%" Set "STARTLVL=0" Set "FOUNDLVL=1024" rem if the argument is the current directory then process everything in it. if "%~f1"=="%CD%" ( rem echo Processing Directory "%CD%" CALL :START %1 SHIFT goto :ARGS ) rem Test if the argument is a directory, if it is move to it then process everything in it, if not then move to the file's parent directory and process the file. Then return to starting directory. Type NUL pushd "%~f1" 2> nul if NOT "%errorlevel%"=="0" ( if NOT "%CD%\"=="%~dp1" ( pushd "%~dp1" Set "DoPop=1" ) Set Pattern="%~nx1" ) else ( rem echo Processing Directory "%~f1" Set "DoPop=1" ) CALL :START %1 if "%DoPop%"=="1" ( popd Set "DoPop=0" ) SHIFT goto :ARGS :START <CURRENT_ARG> color rem Count is superseded by FOUNDLVL but may still be useful for renaming purposes Set "Count=0" rem Process all files in the current directory fitting the arguments search pattern. for /f "delims=" %%y in ('dir %Pattern% /b /od /a-d') do ( if /I NOT "%%~y"=="File Not Found" CALL :Process_File "%%~fy" ) rem if it didn't find anything search all directories instead goto :eof rem if "%Count%"=="0" if %STARTLVL% LSS %FOUNDLVL% ( for /d %%b in (*) do ( pushd "%%~fb" rem echo Processing Directory "%%~fb" Set /a STARTLVL+=1 CALL :START "%%~fb" Set /a STARTLVL-=1 popd ) ) goto :eof :Process_File <FILENAME> color set "V_Q=undef" set "TIMECODE=undef" set "Frame_Rate=undef" set "V_Width=undef" set "V_Height=undef" set "Frame_Rate=undef" set "FULL_HD=0" for /f "tokens=1,2 delims=^=" %%g in ('v:\automazioneclip\core\ffprobe64bit333.exe -hide_banner -loglevel fatal -pretty -select_streams v:0 -show_streams -show_entries stream^=codec_type^,r_frame_rate^,width^,height^,sample_aspect_ratio:stream_disposition^=:format_tags^=timecode^,company_name^,product_name^,product_version^ "%~1" 2^>^&1') DO ( if "%%~g"=="TAG:company_name" set "T_Company_Name=%%~h" if "%%~g"=="TAG:product_name" set "T_Product_Name=%%~h" if "%%~g"=="TAG:product_version" set "T_Product_Version=%%~h" if "%%~g"=="TAG:timecode" set "TIMECODE=%%~h" if "%%~g"=="r_frame_rate" set "Frame_Rate=%%~h" if "%%~g"=="width" set "V_Width=%%~h" if "%%~g"=="height" set "V_Height=%%~h" if "%%~g"=="sample_aspect_ratio" set "V_PAR=%%~h" if "%%~g"=="codec_type" if "%%~h"=="audio" set /a AUCount+=1 if "%%~g"=="codec_long_name" set "codec_long_nameFFprobe=%%~h" ) if "%V_Width%"=="" ( echo ERROR: Video Width NOT FOUND! timeout /t 3 goto :eof ) if "%V_Height%"=="" ( echo ERROR: Video Height NOT FOUND! pause goto :eof ) if "%Frame_Rate%"=="" ( echo ERROR: Frame_Rate NOT FOUND! ) if "%V_PAR%"=="" ( echo ERROR: Video PAR NOT FOUND! pause ) if %V_Width% GTR 801 if %V_Height% GTR 609 set "V_Q=HD" if %V_Width% LEQ 800 if %V_Height% LEQ 601 Set "V_Q=SD" if "%V_Width%"=="720" if "%V_Height%"=="608" Set "V_Q=XDCAM_IMX" if "%V_Width%"=="1920" if "%V_Height%"=="1080" Set "FULL_HD=1" echo "%~1" Using %V_Q% Mode echo PAR = %V_PAR% Set "TokenS=0" Set "SDorIMX=NO" IF "%V_Q%"=="SD" Set "TokenS=1" IF "%V_Q%"=="XDCAM_IMX" Set "TokenS=1" IF "%TokenS%"=="1" Set "SDorIMX=YES" IF "%SDorIMX%"=="" Set "SDorIMX=NO" REM echo SDorIMX assume %SDorIMX% CALL :Make_File_OTHER "%WorkFolder%\%~n1.vcf" "%WorkFolder%\%~n1.avs" "%WorkFolder%\%~n1.avi" "%~f1" echo FATTO echo. echo -------------------------------------------- echo. EndLocal goto :eof :Make_File_Other <VCF_FILENAME> <AVS_FILENAME> <FILENAME> <ORG_FILENAME> rem *** interlaced or progressive recognize procedure *************************************** if exist temp.tmp del temp.tmp Set "scantype=" Set "progressive=" V:\automazioneclip\MediaInfoCLI64bit\MediaInfo.exe --Inform=Video;%%ScanType%% %4 > temp.tmp set /p scantype=<temp.tmp if exist temp.tmp del temp.tmp if "%scantype%"=="Progressive" set "progressive=1" if NOT "%scantype%"=="Progressive" set "progressive=0" IF NOT DEFINED scantype set "progressive=1" rem ***************************************************************************************** Set "codec_nameFFprobe=undef" Set "pix_fmtFFprobe=undef" for /f "tokens=1,2 delims=^=" %%g in ('v:\automazioneclip\core\ffprobe64bit333.exe -hide_banner -loglevel fatal -pretty -select_streams v -show_streams -show_entries format^ %4 2^>^&1') DO ( if "%%~g"=="codec_name" set "codec_nameFFprobe=%%~h" if "%%~g"=="pix_fmt" set "pix_fmtFFprobe=%%~h" ) Set "AudioSource=%4" Set "eventualeIMXcrop=" Set "eventualeColorMatrixDicitura=" Set "eventualeBOB=" Set "IResizeORlanczos=" set "eventualeResize=" if "%progressive%"=="1" Set "TrueFalse=false" if NOT "%progressive%"=="1" Set "TrueFalse=true" if "%progressive%"=="1" Set "IResizeORlanczos=LanczosResize" if NOT "%progressive%"=="1" Set "IResizeORlanczos=IResize" if NOT "%progressive%"=="1" Set "eventualeBOB=.bob().SelectEven()" IF "%V_Q%"=="XDCAM_IMX" Set "eventualeIMXcrop=.crop^(0,32,0,0^)" IF "%timecode%"=="" Set "timecode=00:00:00:00" IF NOT "%FULL_HD%"=="1" Set "eventualeResize=.%IResizeORlanczos%^(1920,1080)" if exist "eventualeColorMatrixDicitura.txt" del "eventualeColorMatrixDicitura.txt" set "eventualeConvertToYUY2=" if not "%pix_fmtFFprobe%"=="yuv422p" IF NOT "%codec_nameFFprobe%"=="dvvideo" set "eventualeConvertToYUY2=.ConvertToYUY2^(interlaced=%truefalse%^)" Set "eventualeColorMatrixDicitura=" IF NOT "%V_Q%"=="HD" echo .colorMatrix(mode="Rec.601->Rec.709")>eventualeColorMatrixDicitura.txt IF NOT "%V_Q%"=="HD" set /p eventualeColorMatrixDicitura=<eventualeColorMatrixDicitura.txt IF NOT "%V_Q%"=="HD" echo eventualeColorMatrixDicitura assume %eventualeColorMatrixDicitura% if exist "eventualeColorMatrixDicitura.txt" del "eventualeColorMatrixDicitura.txt" Set "eventualeScanBottom=" IF "%codec_nameFFprobe%"=="dvvideo" set "eventualeScanBottom=.convertToYUY2^().Crop^(0,1,0,0).AddBorders^(0,0,0,1)" set "fps25forOffset=fps=25," for /f "tokens=1,2 delims=^=" %%g in ('v:\automazioneclip\core\ffprobe64bit333.exe -hide_banner -loglevel fatal -pretty -select_streams a -show_streams %4 2^>^&1') DO ( if "%%~g"=="index" set "audioIndexID=%%~h") Set "streamIndexNumber=undef" if "%NoAudioInsideInputFile%"=="1" Set "streamIndexNumber=0" if not "%NoAudioInsideInputFile%"=="1" Set "streamIndexNumber=1" IF "%AudioProc1%"=="true" Set streamIndexNumber=%audioIndexID% Set "eventualeSmoothFPS2dicitura=" if NOT "%Frame_Rate%"=="25/1" echo .yadif(1,1).SmoothFPS2(50000,1000).AssumeTFF().SeparateFields().SelectEvery(4,0,3).Weave()>eventualeSmoothFPS2dicitura.txt if NOT "%Frame_Rate%"=="25/1" set /p eventualeSmoothFPS2dicitura=<eventualeSmoothFPS2dicitura.txt if NOT "%Frame_Rate%"=="25/1" echo eventualeSmoothFPS2dicitura assume %eventualeSmoothFPS2dicitura% if exist eventualeSmoothFPS2dicitura.txt del eventualeSmoothFPS2dicitura.txt if not exist tempTotale md tempTotale rem echo V_Q assume %V_Q% rem echo audiosource assume %AudioSource% rem echo streamIndexNumber assume %streamIndexNumber% rem echo V_PAR assume %V_PAR% rem echo interlacedORprogressiveFFprobe assume %interlacedORprogressiveFFprobe% rem echo progressive assume %progressive% rem echo eventualeIMXcrop assume %eventualeIMXcrop% rem echo FULL_HD assume %FULL_HD% e eventualeResize assume %eventualeResize% rem ***Make The .avs Script File ************************************************************************************************************ echo Import^("v:\automazioneclip\avisynth\plugins\IResize.avsi"^)>"%cd%\tempTotale\%~n1.avs" echo LoadPlugin^("v:\automazioneclip\AviSynth\Lsmash64perVirtualDub64\LSMASHSource.dll"^)>>"%cd%\tempTotale\%~n1.avs" echo LoadCPlugin("v:\automazioneclip\avisynth\plugins64\yadif.dll")>>"%cd%\tempTotale\%~n1.avs" echo vid=LWLibavVideoSource^(%4^)%eventualeIMXcrop%%eventualeScanBottom%%eventualeResize%%eventualeColorMatrixDicitura%%eventualeConvertToYUY2%%eventualeSmoothFPS2dicitura%>>"%cd%\tempTotale\%~n1.avs" echo aud=LWLibavAudioSource^(%4^, stream_index=%streamIndexNumber%^)>>"%cd%\tempTotale\%~n1.avs" IF "%V_Q%"=="HD" echo left=LWLibavAudioSource^(%4, stream_index=1^)>>"%cd%\tempTotale\%~n1.avs" IF "%V_Q%"=="HD" echo right=LWLibavAudioSource^(%4, stream_index=2^)>>"%cd%\tempTotale\%~n1.avs" IF "%V_Q%"=="HD" echo both=mergechannels^(left^, right^)>>"%cd%\tempTotale\%~n1.avs" IF "%V_Q%"=="SD" echo left=LWLibavAudioSource^(%4, stream_index=1^)>>"%cd%\tempTotale\%~n1.avs" IF "%V_Q%"=="SD" echo right=LWLibavAudioSource^(%4, stream_index=2^)>>"%cd%\tempTotale\%~n1.avs" IF "%V_Q%"=="SD" echo both=mergechannels^(left^, right^)>>"%cd%\tempTotale\%~n1.avs" IF "%V_Q%"=="XDCAM_IMX" echo left=GetChannel^(aud, 1^)>>"%cd%\tempTotale\%~n1.avs" IF "%V_Q%"=="XDCAM_IMX" echo right=GetChannel^(aud, 2^)>>"%cd%\tempTotale\%~n1.avs" IF "%V_Q%"=="XDCAM_IMX" echo both=mergechannels^(left^, right^)>>"%cd%\tempTotale\%~n1.avs" echo audiodub^(vid^, both^)>>"%cd%\tempTotale\%~n1.avs" echo ConvertAudioTo16Bit^(^)>>"%cd%\tempTotale\%~n1.avs" rem ****************************************************************************************************************************************** if exist "%cd%\tempTotale\concatList.txt" del "%cd%\tempTotale\concatList.txt" Set "nonCompleteMXFtoAVS=0" Set "CompleteMXFtoAVS=0" for %%a in ("*.mxf") do if not exist "%cd%\tempTotale\%%~na.avs" set "nonCompleteMXFtoAVS=1" if "%nonCompleteMXFtoAVS%"=="1" set "CompleteMXFtoAVS=0" if "%nonCompleteMXFtoAVS%"=="0" set "CompleteMXFtoAVS=1" if "%CompleteMXFtoAVS%"=="1" for %%f in ("%cd%\tempTotale\*.avs") do echo file '%%f' >> "%cd%\tempTotale\concatList.txt" rem if "%CompleteMXFtoAVS%"=="1" v:\automazioneclip\core\ffmpeg64bit2014.exe -threads 12 -y -f concat -i "%cd%\tempTotale\concatList.txt" -vf scale=interl=1,format=pix_fmts=yuv420p -c:v libx264 -profile:v main -level:v 4.1 -g 33 -bf 2 -crf 23 -flags +ildct+ilme -top 1 -c:a ac3 -b:a 320k -ar 48000 -aspect 16:9 "%cd%\totaleAvisynthHelp.mp4" if "%CompleteMXFtoAVS%"=="1" v:\automazioneclip\core\ffmpeg64bit2014.exe -threads 12 -y -f concat -i "%cd%\tempTotale\concatList.txt" -vf scale=interl=1,format=pix_fmts=yuv420p -c:v libx264 -profile:v main -level:v 4.1 -x264-params me_range=4:subme=1:rc_lookahead=1:chroma_qp_offset=0:8x8dct=1 -g 100 -bf 2 -crf 23 -flags +ildct+ilme -top 1 -c:a ac3 -b:a 320k -ar 48000 -aspect 16:9 "%cd%\totaleAvisynthHelpVeloce.mp4" rem if "%CompleteMXFtoAVS%"=="1" v:\automazioneclip\core\ffmpeg64bit2014.exe -y -threads 12 -f concat -i "%cd%\tempTotale\concatList.txt" -af "pan=stereo:c0=c0:c1=c1" -vn -c:a ac3 -b:a 512k -ar 48000 -aspect 16:9 tempAUDIO.mp4 rem if "%CompleteMXFtoAVS%"=="1" v:\automazioneclip\core\ffmpeg64bit2014.exe -y -threads 12 -y -f concat -i "%cd%\tempTotale\concatList.txt" -vf scale=interl=1,format=pix_fmts=yuv420p -c:v rawvideo -an -f rawvideo - | V:\automazioneclip\core\QSVenc262\x64\QSVEncC64.exe --input-res 1920x1080 --fps 25 --raw -i - --codec h264 --tff --cbr 8000 --bframes 2 -o "%cd%\total.h264" rem if "%CompleteMXFtoAVS%"=="1" v:\automazioneclip\core\MP4Box\mp4box.exe -fps 25.000000 -add "total.H264#video:name=Video" -add "tempAUDIO.mp4#audio:name=Audio" -new "%cd%\totale.mp4" rem if "%CompleteMXFtoAVS%"=="1" if exist total.h264 del total.h264 rem if "%CompleteMXFtoAVS%"=="1" if exist tempAUDIO.mp4 del tempAUDIO.mp4 if "%CompleteMXFtoAVS%"=="1" if exist *.lwi del *.lwi if "%CompleteMXFtoAVS%"=="1" if exist tempTotale del /f /q tempTotale if "%CompleteMXFtoAVS%"=="1" rd /s /q temptotale /s if "%CompleteMXFtoAVS%"=="1" exit goto :eof :GetTargetName color Set "FileName=" Set /p FileName=InputFileName .mxf or InputFolder - INVIO per convertire tutto (EXIT esce): rem Add or remove double-quotes if necessary if NOT DEFINED FileName ( Set "FileName-DQ=" goto :DQSkip ) Set "FileName-DQ=%FileName:"=%" if NOT DEFINED FileName-DQ ( Set "FileName=" Set "FileName-DQ=" goto :DQSkip ) if EXIST "%FileName-DQ%" ( if "%FileName-DQ%"=="%FileName-DQ: =%" ( Set "FileName=%FileName-DQ%" ) else ( Set FileName="%FileName-DQ%" ) ) :DQSkip color if /I "%FileName-DQ%"=="" Set FileName="%CD%" if /I "%FileName-DQ%"=="CD" Set FileName="%CD%" if /I "%FileName-DQ%"=="EXIT" goto :eof if /I "%FileName-DQ%"=="NOEXIT" goto :GetTargetName if DEFINED FileName ( Set /a ARGLVL+=1 CALL :ARGS %FileName% Set /a ARGLVL-=1 ) goto :GetTargetName -
no it serve to encode all mxf to mp4-h264, pre-analizyng the source resolution, framerate, colorspace and scantype. The scantype routine is in blue, but is a little slow
You already call ffprobe and later on mediainfo as well that slowes you down. So can FFprobe give you interlace or progressive scan order? I think that was the reason why I picked mediainfo in my scripts. If ffprobe could do it, just find out that scanorder right away, no delay then. But I think ffprobe cannot do that. I could be wrong it is some years back I was in it. It might be added on since then or I did not look deep enough.
[Attachment 43309 - Click to enlarge]
processing 115 mxf files one time using ffprobe and one time (removing the rem and put rem on the ffprobe routine) using mediainfo:Code:rem *** interlaced or progressive FFPROBE recognize routine ***************************************** Set "progressive=" set "interlacedORprogressiveFFprobe=" for /f "tokens=1,2 delims=^=" %%g in ('v:\automazioneclip\core\ffprobe64bit333.exe -hide_banner -loglevel fatal -pretty -select_streams v -show_entries "frame=interlaced_frame" %4 2^>^&1') DO ( if "%%~g"=="interlaced_frame" set "interlacedORprogressiveFFprobe=%%~h") if "%interlacedORprogressiveFFprobe%"=="0" set "progressive=1" if "%interlacedORprogressiveFFprobe%"=="1" set "progressive=0" echo progressive assume %progressive% rem ***************************************************************************************** rem *** interlaced or progressive MediaInfo recognize routine ***************************************** rem if exist temp.tmp del temp.tmp rem Set "scantype=" rem Set "progressive=" rem V:\automazioneclip\MediaInfoCLI64bit\MediaInfo.exe --Inform=Video;%%ScanType%% %4 > temp.tmp rem set /p scantype=<temp.tmp rem if exist temp.tmp del temp.tmp rem if "%scantype%"=="Progressive" set "progressive=1" rem if NOT "%scantype%"=="Progressive" set "progressive=0" rem IF NOT DEFINED scantype set "progressive=1" rem *****************************************************************************************
ffprobe: 07 minutes and 57 seconds
mediainfo: 00 minutes and 25 seconds
ok,ffprobe checks every frame or something
https://github.com/MediaBrowser/Emby/issues/68
mediainfo just reads one value, does not check anything, so if checking a camcorder footage, it is always accurate, as long as camcorder flags it properly
Staxrip 'Failed to open source, try another source filter?'
By hanaluluelle in forum Video ConversionReplies: 0Last Post: 1st Mar 2017, 02:44 -
Is there a way to hardcode subtitles so quickly in Xvid4PSP?
By rammon02 in forum SubtitleReplies: 3Last Post: 12th Feb 2016, 07:44 -
How to see correct timecodes quickly...
By falco2000 in forum Newbie / General discussionsReplies: 6Last Post: 21st Jan 2013, 20:37 -
mpg to dvd via edits quickly and easily as possible... ?
By abrogard in forum Authoring (DVD)Replies: 7Last Post: 20th Jan 2013, 15:44 -
What setting should I choose to create a dvd quickly?
By norcim in forum Authoring (DVD)Replies: 2Last Post: 25th Oct 2012, 09:45
