I wonder why you have not simply downloaded a short file from the Internet and those various media players to answer your own question.
The short answer is 'Yes, your laptop is powerful enough with that spec laptop'.
I use MediaPortal to play media files with a nice frontend. You could use VLC.
SamT -
Hi,
as you mentioned that MPC-HC is dead, i think it will return. If you likes it you can switch to MPC-BE (black edition). I personaly prefer Potplayer where you can set process priority and change videorenderer on the fly.
Test video players you mentioned. Watch how smooth is playback and audio/video sync.
Bernix -
Hi,
your processor supported Intel QuickSync. You can try in Potplayer - preference - filter control - open codec And here Enable Intel QuickSync Decoder. Just try it if playback is bit better.
But according to wikipedia it will helps you only with h264...
BernixLast edited by Bernix; 5th Oct 2017 at 09:21.
Problems with playing 4k x265 files
By Teague in forum Software PlayingReplies: 7Last Post: 29th May 2019, 01:30 -
FFMPEG x265 10bit and virtualdub x265 10bit settings
By lilycarolyn in forum Video ConversionReplies: 11Last Post: 6th Jun 2016, 13:44 -
Is x265 ready for Primetime.. Migrating From x264 to x265..
By RazorBurn in forum Video ConversionReplies: 83Last Post: 31st Jan 2016, 07:14 -
What Is The Best X265 Video Converter??
By DJboutit in forum Video ConversionReplies: 1Last Post: 20th Dec 2015, 02:13 -
Cutting of x265 video file
By jswl.dty in forum EditingReplies: 17Last Post: 24th Jan 2014, 11:49
