Has anyone ever used the excellent VSDC free screen recorder?
I am trying to highlight the cursor using layers selection, without success.
How is it possible?
Thanks.
Easiest solution is to change the system settings in windows, adding/using a custom cursor.
I particularly like these beveled ones: http://www.rw-designer.com/cursor-set/blue-3d-beveled
Some helpful sites on 'how to' below:
https://www.digitalcitizen.life/how-customize-mouse-cursors-windows-7
https://www.digitaltrends.com/computing/how-to-change-mouse-cursor-pointer-windows/
Edit: forgot that cursor can be highlighted on demand too, by pressing 'ctrl': https://www.youtube.com/watch?v=WcC6eNfXjDILast edited by transporterfan; 5th Oct 2017 at 06:22.
[SOLVED] ZD Soft Screen Recorder
By suadnovic in forum Capturing and VCRReplies: 10Last Post: 27th Aug 2015, 22:31 -
VSDC Split-Screen and merge videos
By SimBeam in forum EditingReplies: 3Last Post: 18th May 2015, 16:22 -
Reccommend a screen recorder and format
By u222683 in forum Video Streaming DownloadingReplies: 8Last Post: 7th May 2014, 17:43 -
PotPlayer - How to unhide pause/play menu on mouse movement in full screen?
By tahayassen in forum Software PlayingReplies: 3Last Post: 30th Jan 2014, 21:02 -
2 Microsoft Screen Recorder Tools
By Tom Saurus in forum Video Streaming DownloadingReplies: 6Last Post: 14th Nov 2012, 17:00
