I'm wondering if something peculiar about your dpx sequence ? There many different dpx variations, are they from the same batch and type? Same characteristics, dimensions too ? Also are named and numbered correctly ?
Can you upload a sample , and zip(archive) it up ? For example the 4 frame sequence . If it's a bug with vdfm / vdub, then perhaps something can be done about it. because it seems to work ok here
imwrif not imwri
i tried to autoload imageMajick (using this directory: C:\Program Files (x86)\VapourSynth\plugins64\libimwri.dll)
with this code:
i get this error line 3Code:import vapoursynth as vs core = vs.get_core() video = core.imwri.Read('D:/test.%06d.dpx') video.set_output()
Failed to evaluate the script: Python exception: No attribute with the name imwri exists. Did you mistype a plugin namespace?
also specify firstnum=whatever for the first number in the sequence
Results 31 to 52 of 52
I don't think anyone has "translated" videofred's script into a native vapoursynth equivalent, but it should be possible, all the building blocks are there.
But you can actually load vapoursynth scripts into avisynth with vapoursource using vsimport() . So if the only way you can get a dpx sequence (easily) loaded is with vapoursynth, you can still apply the existing videofred script in avisynth
If it's just a short sequence, the ffms2 and single splices isn't that bad in avisynth -
what the!???imwrif not imwri
the documentation shows imwri:
http://www.vapoursynth.com/doc/plugins/imwri.html
and imwri is all over the main doom post:
https://forum.doom9.org/showthread.php?t=170981
my god, how did you know it was changed? (don't answer that
so i have gotten rid of the previous error, and now it appears to be simply a matter of how to bring in a proper image sequence.
i'm using this now:
and getting this error:Code:video = core.imwrif.Read(filename="D:/Data/Downloads/VapourSynth/test/footage/test.%06d.dpx", firstnum=1)
my dpx files look like this:Python exception: Read: No files matching the given pattern exist
test.01.dpx
test.02.dpx
test.03.dpx
test.04.dpx
i uploaded a 44mb zip of these files. my dpx sequence is coming from a single transfer source. i can't imagine or see that there is a difference between each frame.
thank you! -
It should be "%02d" , because you have 2 placeholder digits (not "%06d", which would mean 6 digits)
Yes, the documentation needs updating -
i'm sorry i should have researched that one. its just that there have been so many problems that that one got buried.
i will try to get into vapourSynth and frame serving it to adobe premiere as well as studying the possibilities of finding a similar script for film restoration. (in other words, i'll be back!)
i need deflicker, stabilization, degraining, sharpening, and most importantly (and i can live without all of them but this one) temporal dirt cleaning.
thank you so much. you are amazing.
(and thanks to everyone helping tirelessly on this thread!) -
I can reproduce the vdfm sequence issue . shekh is the author of that fork, and he's posted earlier in this thread, so I think he should be investigating the issue . The dpx themselves look ok, and import fine in other programs that support dpx - nothing looks out of the ordinary. So it probably is an issue specific to vdfm
If you just want something done now, I would go the VSImport() route in avisynth and use your existing workflow/script (basically just using the vpy to "read" the sequence.). There are a lot of "gotchas" in vapoursynth (I guess quite a few in avisynth too, but you've been using that so are at least familiar with a workflow that works for you) . But you can revisit vapoursynth when you have more time
But one "gotcha" you're going to have right off the bat is IM plugin imports as float in vapoursynth, so you would probably need to convert to a compatible colorspace/depth before sending it somewhere . Avisynth+ supports some additional depths and colorspaces, but not floatLast edited by poisondeathray; 9th Oct 2017 at 01:09.
dpx sequence problem fixed in build 40412 https://sourceforge.net/projects/vdfiltermod/files/VirtualDub%20pack/version%2017/
Caused by framerate stored in pictures (15 in the example) -
thanks, guys. you are amazing. i had to go back to work monday and today. hopefully i'll get some time to test this tomorrow. thank you!
I can confirm the new version of VirtualDub FilterMod autoloads all four DPX files, 1 through 4.
Finally able to get off work to test this.
i can confirm that large dpx sequences (hundreds of frames) are importing normally into vdfm now. thank you so much shekh.
frameserving a 58 frame dpx sequence from vdfm 32bit to avisynth is causing a crash in vdfm
however, vdfm 64bit is not crashing with any of my sequences.An out-of-bounds memory access (access violation) occurred in module 'VirtualDub'... ...reading address 00000000
i can import this vdr into a simple avs scipt and use avfs to frameserve this a 2nd time to vlc or adobe premiere.
unfortunately, if i use my restore film script from videoFred, vlc still works, but adobe premiere throws this error:
when i get some time, i'll try and see if a specific plugin in the restore film script is causing the problem. but i'm guessing its actually just too many filters, perhaps.import failure. unsupported format or damaged file
i've been testing your idea to use VSimport of a vapourSynth script using the vapourSource plugin in avisynth. however, i can't get the darn plugin to load.
i've got vapourSource 0.1.0 in my plugin folder but
LoadPlugin("plugins/VapourSource.dll")
is throwing the usual error:
i'm not sure i need this now that vdfm is working anyway, but...unable to load. module not found. Install missing library?
thank you! -
Can you check with taskmanager the memory usage? Just curious
You might need to convert to RGB24 or 32 at the end of the script. There are a few versions floating around but IIRC, most of that script is running in YV12 or YUY2i can import this vdr into a simple avs scipt and use avfs to frameserve this a 2nd time to vlc or adobe premiere.
thank you!
Not sure about x86 but it works with x64 and avisynth+ MT x64
Also, not sure if fred posted the updated version yet, but IIRC I think he mentioned updating his script for avisynth+ MT x64 . It's significantly faster and more stable than the old avisynth MT -
I think we have full resolution here to everything! You are a madman, Mr. Deathray! I added a converttoRBG24 at the end of the script and it opened and ran in adobe premiere fine.
Here are the full details of the workflow:
In order to open and filter (remove dirt and scratches, etc) a DPX (or tiff, etc) sequence in AviSynth and then frame serve that to Adobe Premiere:
1. Open the .dpx sequence in VDFM
2. Use VDFM's built-in frame server to serve the file as a .vdr file (or .avi). (I could only get this to work in VDFM 64bit see this link to get the frame server working:
https://github.com/stax76/staxrip/issues/159#issuecomment-299569068)
3. Create an AviSynth .avs script that opens that .vdr file (To import the file later into Adobe Premiere make sure the final file is converted to RGB24 or 32 in the script)
4. Use AVFS to frame serve the .avs script into a virtual .avi file (I used the simple command line: "avfs test.avs" to build the virtual .avi file)
5. Open the .avi file in Adobe Premiere
A filtered virtual avi file will barely function in the premiere timeline. So I plan to edit the film using the original dpx sequence. Then after the edit is complete, I hope to replace all the footage with AviSynth filtered (restored and cleaned) virtual avi files. Then I'll hit render and hope it doesn't take 3 weeks!
Seems so easy now, but i had a tragic head-scratcher at every step.
Thanks so much to everyone that has helped with this project. You are incredible!
(I'm realizing this whole plan is probably a crazy dream anyway. I have about 50+ dpx source sequences to edit in premiere. So to replace then all with virtual avi files, I'll have to open 50+ instances of VDFM and start frame servers. Then do the same with AVFS, if that is even possible!)Last edited by procedure; 12th Oct 2017 at 18:34.
hi. obviously this is not going to be too scientific.
i have an i-7-6700k cpu with 16gb of ram running windows 10.
i tried it again and shut down every other program on my computer and noticed that before launching VDFM 32bit:
cpu 2-5%
Mem 27%
when i hit play on the avs with a simple vdr import in AvsPmod, around the moment of the crash it was around:
cpu 25%
mem 35% -
Fixed more bugs including the crash in 32bit. https://sourceforge.net/projects/vdfiltermod/files/VirtualDub%20pack/version%2017/
hi shekh. this seems to be the same release as the previous release build 40412. however, the crash appears to be gone now. not seeing a crash anymore. thanks very much!
Open AAC With AviSynth
By koberulz in forum Newbie / General discussionsReplies: 15Last Post: 9th Oct 2016, 17:21 -
How to import dpx. files to premiere as clip
By henry7121 in forum Newbie / General discussionsReplies: 4Last Post: 19th Dec 2015, 09:17 -
how to open mpeg2 video files in avisynth without the ffms2 plugin?
By marcorocchini in forum Newbie / General discussionsReplies: 4Last Post: 26th Oct 2015, 07:59 -
avisynth 2.6 + ffms2 2.22: why don't open mxf (mpeg2) video files?
By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 6th Sep 2015, 13:19 -
Can't open AviSynth in VirtualDubMod
By atamo in forum EditingReplies: 21Last Post: 8th Sep 2013, 07:30
