When you install a new version of DAUM PotPlayer, you are asked if you want to download additional Codecs.
If you don't do it and you finish installation, how do you *manually* do that after the installation is finished?
and a separate question:
Is there a reputable web site download location for those additional codecs to be manually installed offline?
Only page I found providing opencodec setup 64 is http://get.daum.net/PotPlayer/Codec/OpenCodecSetup64.exe or http://get.daum.net/PotPlayer/Codec/OpenCodecSetup.exe 32bit version
It is rated 9/10 same as videohelp.com according to ssleuth so it is good protected page. I checked the file with windows defender and it is clean.
Hope it helps. It is digitaly signed file.. but nowadays, who knows
But I believe it is clean.
Bernix -
I suppose I could also do a reinstall and just run the Codec Updater when it asks at the end...
But you would think there would be a way to launch that from within a program? -
Hi,
yes, reinstaling is first what comes to my mind. This is best solution.
Bernix
DAUM PotPlayer skin customizations
By c627627 in forum Software PlayingReplies: 30Last Post: 31st Oct 2024, 14:05 -
How to setup Daum PotPlayer to output TrueHD and DTS-HD
By c627627 in forum Software PlayingReplies: 9Last Post: 16th Feb 2022, 22:33 -
DAUM PotPlayer - Save downloaded subtitles automatically
By Shasoosh in forum Software PlayingReplies: 0Last Post: 23rd May 2015, 03:03 -
DAUM PotPlayer won't work with iMON Remote
By ElLoboSolitario in forum Newbie / General discussionsReplies: 1Last Post: 26th Dec 2014, 06:45 -
Can't find DVD/BD menu's on Daum Potplayer, any help?
By joruyyy in forum Software PlayingReplies: 6Last Post: 3rd Dec 2012, 03:38
