Hi please can help a poor cat?
in avisynth 32 bit I was using ReverseFieldDominance() from ReverseFieldDominance.dll that probably was written for 32 bit.
But now I have avisynth 64 bit it don't work
Is there a way to obtain the same results in the 64bit enviroment? thanks
ps: he is for DVCAM .mxf files
ComplementParity() changes the assumed field order but make no changes to the video itself.
If you want to convert a TFF video to a BFF video you can either:
orCode:SeparateFields().Trim(1,0).Weave()
The latter won't work with interlaced YV12 video. It will work with RGB, YUY2 and YV24.Code:Crop(0,1,0,0).AddBorders(0,0,0,1) # remove one scanline off the top, add one at the bottom
How to Convert 10-bit to 8-bit with AviSynth?
By MrBiggles in forum Video ConversionReplies: 4Last Post: 6th May 2015, 05:38 -
What 10-bit colorspace can I use with avisynth?
By -Habanero- in forum Newbie / General discussionsReplies: 20Last Post: 26th Apr 2015, 00:12 -
AVISynth Reverse is slow
By smike in forum EditingReplies: 7Last Post: 20th Apr 2015, 10:27 -
swap field order in avisynth
By marcorocchini in forum Newbie / General discussionsReplies: 3Last Post: 20th Sep 2014, 15:04 -
if I reverse field dominance I loss quality?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 17th Jun 2014, 17:35
