I have a video with two audio tracks that have been overdubbed in other languages. I want to do a direct stream copy of the video, and a separate English audio file.
But the two are out of sync. So I go to the audio interleave to adjust the delay but when I play the output (right play button) the video doesn't play. I just get a static picture, which updates to the current frame when I pause. The audio plays.
That's utterly useless for adjusting audio sync. The video has to be moving in order to tell if the delay has been set correctly. I'm not going to do a stream copy 50 times trying to hone in on the right setting.
Playing the input, with the audio waveform display on, the video plays but the audio doesn't scroll across, only updates its location when paused. Not very useful for trying to pin down how far off things are.
I have a six core FX6100 CPU and 8 gigs RAM with Windows 10 Pro x64.
For syncing I find it faster to use MPC to get the adjustment value.
https://latestsolution.com/how-to-fix-audio-and-video-out-of-sync-mpchc/
Hope that helps you some. Someone else may have the VirtualDub playback solution. -
There are several suggestions that have worked for different people in the thread https://forum.videohelp.com/threads/289125-No-Video-In-Virtual-Dub-Just-Audio. Might try some of them for the playback problem.
Virtualdub Input video turns green when it's the active window.
By digicube in forum EditingReplies: 3Last Post: 1st May 2017, 19:13 -
VirtualDub - Resizing video frame, output size is huge??
By giantqtipz in forum Newbie / General discussionsReplies: 4Last Post: 22nd Aug 2016, 08:04 -
can I output the playback video window to ... (pls enter cats only thanks)
By marcorocchini in forum Newbie / General discussionsReplies: 11Last Post: 18th Aug 2014, 15:52 -
Virtualdub output pane showing input video?
By anonymousthing in forum Video ConversionReplies: 10Last Post: 20th Jun 2014, 10:12 -
VirtualDub output file doesn't play (it's nnnn frames of one image)
By XXL in forum Newbie / General discussionsReplies: 0Last Post: 22nd Nov 2013, 22:37
