Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. Hi
    Im trying to get a vid into virtual dub to try and edit it
    I converted the file to avi
    I drag and drop only to get this notice .....
    could nt locate decompressor for format
    virtual dub requires a video for windows VFW COMPATIBLE CODEC to decompress video
    Direct Show codects such as those used by
    Windows Media Player are not suitable
    any one any idea what I can do about this ?
    thanks for any advice
  2. Member DB83's Avatar
    Jul 2007
    Can you actually play the avi you created ?
    So, assuming the positive, firstly download mediainfo , load the avi in to that, select text mode and post the report here - if you need to edit or remove the first line ie the one with the title then that is not important.
    Or depending on the original you can install filters for vdub and load the file direct - no conversion to avi. Or just try virtualdubfiltermod.
  3. VirtualDub FM opens more file types. Try it.
