when i open the TMPGEnc program and i select the video source
it says it cannot open or file unsupported. I have already used virtualdub
and the audio source opens fine its just the video iam having problems with.....any ideas?
thanks
gnikdrazil
had this problem as well, tmpgenc appearently does not recognize all codecs, solution is simple: fire up vdub, export the audio stream, then select in tmpgenc the audio stream you just exported... you might have to use 'full processing' to simple pcm in vdub to have tmpgenc swallow the audio though...
... this copy of me hasn't been registered for the last 36 years! (no spamming please) -
can you play the file in WMP w/video? It sounds to me like you just don't have the right codec for this file. the other thing you could try is to increase the priority of the directshow reader under environmental settings in TMPG, but if you're not getting video in VDub either, I think that it is the codec. try the nimo codec pack in the tools section.
second time i see a reference to the directshow reader priority... could someone explain to me exactly what this setting does? override other codecs with its own filters?
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
tmpgenc 2.5 plus problem
By DSLGuy in forum Video ConversionReplies: 1Last Post: 3rd Apr 2008, 14:38 -
Problem with TMPGEnc
By The Monkees in forum Video ConversionReplies: 2Last Post: 1st Nov 2007, 15:58 -
TMPGEnc Problem
By djkevyb in forum Newbie / General discussionsReplies: 3Last Post: 27th Sep 2007, 15:46 -
TMPGEnc Problem !!!!!!!!!!!!!
By homantam in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2007, 17:56
