Why i getting 1.222 Display aspect ratio and not 4:3? Is correct this? Thank any help
SetMTMode(3)
DirectShowSource("C:\Documents and Settings\USER\Desktop\Sample-1991 MX 250 Full.mpg")
SetMTMode(2)
ConvertToYV12
SeparateFields()
PointResize(width,height*2)
Deblock_QED(last, quant1=35, quant2=40, aoff1=4, boff1=4, aoff2=4, boff2=4)
PointResize(width, height/2)
Weave()
QTGMC(preset="Slower")
aWarpSharp(depth=5)
nnedi3_rpow2(2, cshift="Spline64Resize", fwidth=width*2, fheight=height)
Sharpen(0.5, 0.0)
ColorYUV(gain_y=-48)
Crop(2,10,-6,-16).AddBorders(4,12,4,14)
AssumeTFF().SeparateFields().SelectEvery(4,0,3).We ave()
SOURCE:
General
Complete name : C:\Documents and Settings\USER\Desktop\1991 MX 250 Full.mpg
Format : MPEG-PS
File size : 944 MiB
Duration : 1h 17mn
Overall bit rate : 1 713 Kbps
Writing library : (c) 1998-2012 Womble Multimedia, Inc. / MPEG Video Wizard DVD 5.0.1.100 (03/2011) / Dec 6 2012
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : Variable
Duration : 1h 17mn
Bit rate mode : Variable
Bit rate : 1 486 Kbps
Maximum bit rate : 9 396 Kbps
Width : 352 pixels
Height : 576 pixels
Display aspect ratio : 4:3
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.293
Time code of first frame : 00:00:00:00
Time code source : Group of pictures header
Stream size : 820 MiB (87%)
Color primaries : BT.601 NTSC
Transfer characteristics : BT.601
Matrix coefficients : BT.601
Audio
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Muxing mode : DVD-Video
Duration : 1h 17mn
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel count : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 106 MiB (11%)
RESULT
Format : AVI
File size : 227 MiB
Duration : 49s 600ms
Overall bit rate : 38.4 Mbps
Writing library : VirtualDub-MPEG2 build 24586/release
Video
Format : Lagarith
Codec ID : LAGS
Bit rate : 36.9 Mbps
Width : 704 pixels
Height : 576 pixels
Display aspect ratio : 1.222
Standard : PAL
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 3.640
Stream size : 218 MiB (96%)
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 1
Bit rate : 1 536 Kbps
Bit depth : 16 bits
Stream size : 9.08 MiB (4%)
Alignment : Aligned on interleaves
Interleave, duration : 40 ms (1.01 video frame)
Interleave, preload duration : 500 ms
Results 1 to 12 of 12
Yes, use a player that properly supports the DAR flag.
It will stretch it to 4:3 during playback.
Scott -
As Scott states you can force playback in players such as vlc with the Aspect Ratio set at 4:3.
But I do not believe this to be an ideal solution as you would have to do it each time you play the video.
Surely it is better to edit your avisynth script to include a resize. Eg:
Spline64Resize (768,576)
I am no expert in avisynth and someone could probably suggest a more elegant solution to the above one. But what I did notice is that your original script had re-interlaced the fields >> Weave() << BEFORE the command to double the video width. Surely that should be done in the progressive realm ? -
What do you care what it is with Lagarith as it won't be your final format. Whatever is the intended final format, either set a SAR/DAR when encoding or resize to square pixel when making the Lagarith AVI the first time.
The best way is as you're doing it already (I think). Make a D2V project file using DGIndex and open it using MPEG2Source.But if I demux the video and use Mpeg Source I'm correct with Lagarith , but I did not want to do it this way
would have some way, via directshow? -
Thanks for all (All the same), I going to MPEG2Source, but I'll test this before: Crop(2,10,-6,-16).AddBorders(4,12,4,14)
AssumeTFF().SeparateFields().SelectEvery(4,0,3).We ave() (Thanks)
PS:Are you in a bad mood today, master?
Is that meant for me? If so, haven't you done enough video work to know AVIs don't usually have a DAR flag, and it doesn't matter anyway if a Lagarith AVI is just an intermediate file? If you did know, this whole thread is pointless. If you didn't know, DB83 gave you the answer in the first reply and the rest of the thread is pointless.
And the end format is MP4 or MKV or something besides DVD, I presume, and you're keeping black on all four sides around it? You must have your reasons, I suppose. Overscan, maybe? If you posted a sample, maybe someone could provide more informed advice. -
The topic would be useless if I did not get any help, any answer.
F-i-v-e S-t-a-r-s
How about some coffee now? Thanks all
Aspect ratio as a number rather than a ratio
By pooksahib in forum Newbie / General discussionsReplies: 38Last Post: 22nd Aug 2017, 18:18 -
Converting 1:85 aspect ratio to 2:39 aspect ratio using Virtual Dub
By maxgremlin in forum EditingReplies: 1Last Post: 8th Jun 2017, 22:06 -
Help re-encoding mkv to fix display aspect ratio
By bowiebowie in forum Video ConversionReplies: 13Last Post: 17th May 2016, 10:19 -
Display Aspect Ratio ?
By KingCraft in forum EditingReplies: 9Last Post: 2nd Jul 2014, 10:40 -
DVD to MP4 conversion - display ratio
By jnyfive in forum Video ConversionReplies: 2Last Post: 17th Jul 2013, 20:00
