My PotPlayer is working perfectly in most cases.
However, there are some videos PotPlayer would give me no sound.
I have checked the audio codes using MediaInfo, and I cannot find any difference in terms of code between those have sounds and those do not.
VLC player, WMP and Films & TV can play those videos perfectly (with sound).
I still want to use PotPlayer because I cannot use madvr in WMP.
Any help would be greatly appreciated. Thank you for your time.
Hi,
you can provide Mediainfo report of files, that are o.k. and that are not.
You can try to save your Potplayer settings and then initialize potplayer. If it solved your problem, so problem is in your custom configuration. Or check if correct audiotrack is played in potplayer. Audio -> select audio stream.
But first try to initialize potplayer (with back up your curent settings)
Bernix -
Hi Bernix,
Here is an example, comparing two videos:
With no sound:
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 51 min 33 s
Bit rate mode : Variable
Bit rate : 317 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 spf)
Compression mode : Lossy
Stream size : 117 MiB (6%)
Language : English
mdhd_Duration : 3093845
With sound:
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 20 min 51 s
Source duration : 20 min 51 s
Bit rate : 125 kb/s
Stream size : 18.6 MiB (2%)
Source stream size : 18.6 MiB (2%)
Language : English
mdhd_Duration : 1251840
I haven't initialized my main PotPlayer, but I have downloaded a fresh new PotPlayer 64bit version, but it still cannot play with sound.
I have also tried MPC (HC & BE) but still no luck.
It seems that only the video players like WMP, VLC or Films & TV can play those videos with sound. (those do not have custom control for filter and decoder)Last edited by logydream; 30th Sep 2017 at 15:12.
Hi,
possibly corrupter. Try download Mkvtoolnix and remux to mkv. But I know sometimes is MP4 needed for user. Just for record.
Just open mp4 and then press start muxing. But do not very much believe it will helps. And my mediainfo on my encoded video files doesnt never report variable bitrate AAC.....
Bernix -
Or you can in preference - filters settings - audio decoders set aac decoder to system default instead of build in.
Bernix
How to show subtitle with MP4 files on WMP with media foundation enabled?
By POP3D in forum Newbie / General discussionsReplies: 2Last Post: 30th Aug 2017, 07:37 -
Getting .srt forced subtitles to work on .mp4 in WMP 12 (Windows 8.1)
By dianatro in forum Newbie / General discussionsReplies: 2Last Post: 8th Jul 2015, 06:51 -
PotPlayer plays a movie with no audio
By alek8976 in forum Software PlayingReplies: 5Last Post: 13th Mar 2015, 10:22 -
WMP & WMC suddenly stopped playing my mp4 files
By satwar in forum Newbie / General discussionsReplies: 2Last Post: 9th Apr 2014, 22:40 -
Potplayer having problems playing some MP4 files
By fenson in forum Software PlayingReplies: 2Last Post: 25th Oct 2013, 11:50
