Okay, when I tried convert my movie it says that my MPEG2 has expired. I donwloaded the codec already but I don't know how to make it work.\
Thanx
what are you using to convert to mpeg2? If it is Tmpgenc they do have a 30 day limit. The older versions did too, but you were able to just reinstall the software.......
So I should use the earlier versions? If so what version would be the best to download?
Thanx
How to import MPEG2-TS to Adobe Premier? How to convert MPEG2-TS to MKV? :)
By farzad in forum EditingReplies: 19Last Post: 29th Feb 2012, 17:25 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 19:45 -
can not convert to mpeg2-dvd
By lartomar2002 in forum Video ConversionReplies: 4Last Post: 28th Sep 2010, 13:07 -
How do I convert .ts to .mpeg2?
By Zippity in forum Video Streaming DownloadingReplies: 1Last Post: 29th Mar 2010, 20:43 -
convert hd pal mpeg2 file to hd ntsc mpeg2 file
By gearo in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jun 2008, 02:12
